Horn doesn't work 1985 power ram W150
Discussion in 'General Discussions' started by Brucecmc, Nov 21, 2016.
  1. Brucecmc
    Brucecmc Senior Member
    123
    Nov 21, 2016
    At the parts store
    Ram Year:
    1985 Power Ram W-150
    Engine:
    318 V8 5.2L
    Another pic
    Another pic
  2. Brucecmc
    123
    Nov 21, 2016
    At the parts store
    Ram Year:
    Engine:
    318 V8 5.2L
    Pic3
    Pic 3
  3. crazzywolfie
    crazzywolfie Senior Member
    14,101
    2,147
    Apr 6, 2013
    under the truck
    Ram Year:
    81 93
    Engine:
    5.2
    glad to hear you got it working again
  4. Sniper X
    Sniper X Senior Member
    50
    113
    10
    Dec 7, 2016
    Ram Year:
    1991
    Engine:
    318
    Bad ignition switch. But replace all the fuseable links with fuse holders and fuses. Or new fuseable links. This will clear up or keep from happening a LOT of wonky Dodge truck electrical problems.
  5. Sniper X
    50
    113
    10
    Dec 7, 2016
    Ram Year:
    1991
    Engine:
    318
    Yes because the relay is downstream of the horn button and therefore the power is still going thru the button. In a relay system the button supplies only suppy voltage to trigger or "pull" the relay. What happens is the button has a low amperage supply voltage to one side of the relay, the device hooked to the relay has a higher amperage load on one side and when you touch the button, it switches the ralay to supply the device with the higher amperage from the other side of the relay therefore making it possible to have much smaller wires run to the button and in the cabin of the vehicle so it is more managebale, and it also has a second result of not havig the switches for everything be huge to take the entire load of a device that needs more than just a few amps.
Share This Page
