How add OEM rear Park Assit
jfaubin
Hi, it is possible to add a OEM rear park assist on ram sport without park assist? I known park assist use module located in dash. I would information if guy here have already added.
J-F
Divi
I'd assume you can, I have been looking into this aswell. From what I have gathered you have to get the module, harness for bumper, sensors, and sensor surrounds. I have not verified that the harness connector is in the rear of the truck yet or the connector for the module though.
J
jfaubin
Nice, do you have a part number?
Divi
No, I can find diagrams online for rear bumper and parts but they never have the harness part number. Plan to call my dealer and ask them for the number. Will post it here when I find out. We will also need to flash the pcm with the sales code to activate.
Divi
I'm guesstimating cost of about $500 to test this theory and see if it will work or not. But i'm not pulling the trigger till I verify the plugs are on my truck.
J
jfaubin
Nice, where is located this plug in the dash?
Divi
Heard above rear passengers back seat behind head board thingy.
0212353
Vendor
Preferred Vendor
Florissant, MO
2x 5.7L & 6.2L
Just a note.......when I looked up the parts.....the sensors are $80 per (need 4) and the bezels are $15 per (again, need 4). Almost $400 in just sensors there....
Orlando,FL
We're currently developing a OEM fit kit that will be in the range of 450-500 not including the rear bumper.
J
jfaubin
Hi, i find a rear bumper assy with sensor and short harness for less than 500$ Canadian. The module seem to be 30 to 75$ in salvage place
Divi
okay here we go, some research and ive got the following info...
you will need:
Park assist module $155 68204477AD
Rear Harness $90.00 68031820AA
Sensor x4 $112.00 1EW63TZZAA
Bezel inner x4 $20.00 5LT35ZZZAA
Bezel Outer x4 $20.00 5LT36ZZZAA
And then the switch panel that matches your other options.
The prices are dealer prices you can find them elsewhere cheaper.
Divi
Ohh and you will need to have the dealer flash in sale code for the rear park assist, i have not found that yet though.
baum
savage, mn
2015 Laramie
you can actually get really nice aftermarket kits that lets you adjust the distances. all it is really is sensors and control module. two wire hook-up and mounting and running the wires for the sensors.
Divi
After market doesnt fully itnergrate with EVIC, I personally am looking for full intergration.
J
jfaubin
Me also. OEM only!
Do you known if the harness for the module is included by default at the passenger side ine the headliner?
Divi
Me also. OEM only!
Have not got that far, need to look under the rear bumper to for the other harness.
J
jfaubin
where is located near the rear bumper?
J
jfaubin
Rear drivers side from the looks of it
ok and it supposed a plug with many cables or just two cables? i have a cables with shrink tube at the end of the cables. Do you have part number of this harness?
