How add OEM rear Park Assit
Divi
ok and it supposed a plug with many cables or just two cables? i have a cables with shrink tube at the end of the cables. Do you have part number of this harness?
Part numbers are a few posts before this one
J
jfaubin
i'm not sure. the harness 68031820AA, is the harness attached with the bumper. This is not the harness from rear bed to interior near the passager side.
Divi
Yes this is the one that goes along the rear bumper, it should connect over by the drivers side tail light.
J
jfaubin
okay here we go, some research and ive got the following info...
you will need:
Park assist module $155 68204477AD
Rear Harness $90.00 68031820AA
Sensor x4 $112.00 1EW63TZZAA
Bezel inner x4 $20.00 5LT35ZZZAA
Bezel Outer x4 $20.00 5LT36ZZZAA
And then the switch panel that matches your other options.
The prices are dealer prices you can find them elsewhere cheaper.
I'm search for buy and test, but i'm not sur if the interior harness for the module 68204477AD is already included.
J
jfaubin
We're currently developing a OEM fit kit that will be in the range of 450-500 not including the rear bumper.
Your kit use oem module and work like the oem? Do you known if the wire for park module is already at the passager side?
J
jfaubin
Hi, do you have an update for your OEM fit kit? please explain your kit.
Regards
[email protected]
Preferred Vendor
Pardon for the delay,
I just received word we currently have a tester who was just shipped a kit and we are waiting to hear back some results.
:cheers:
catmatton
Following as i also am interested in this but for the 18's
[email protected]
Preferred Vendor
I was just informed that this has been set aside for other projects, specifically the UAS/UAQ (Android Audio/Carplay) upgrade for the 13+ RAMs. It's not completely off the table, however the guys in programming ran into some issues when digging deeper into adding rear park assist.
BWL
Embrace the skeptisism
BC Canada
Good rear view camera is handy. Rear park sensors are a finicky pain in the ass. I recommend if you don't have them don't get them and count yourself lucky. Mine work at most 2 months year. Rest of the time they're either broken or too snow or dust or rain covered to work. I replace the 1 or 2 that fail at the start of every summer and by the end of summer at least 1 more is nfg and I leave it till the following year.
BWL
BC Canada
I have the oe ones
