14hemiexpress
The B&W stow and go is worth every penny. I have a 3in drop one on my work truck and I have the tri ball set up and it's perfect haven't come across a trailer that I haven't been ready to pull.
Got a similar lift as I do? I think I need 5 or 7 to be safe.The B&W stow and go is worth every penny. I have a 3in drop one on my work truck and I have the tri ball set up and it's perfect haven't come across a trailer that I haven't been ready to pull.
Cheers!My work truck is a stock gmc z71. For a truck that's around 4 inches taller than stock a 5-7 is what will be needed. I probably would look more towards the 7in
I’m running a Superlift 4/3 Lift on 35’s and I need a 10” drop to get my 5x10 utility trailer to sit level
Boat loading ease is more dependent on experience and the trailer position in relation to the water than the bunk or winch stand position in relation to the axles.
On mine, which is a drive on trailer, that would not be enough (lug nuts in the water).
Cheers!
I actually went 5" because my rear bumper weighs as much as stuffed burrito.@SoCal just got a similar lift Zone 4/3 with Fox 2.0, Bils @ 0.7 with 35s (295/65R20) and looking at the B&W 7" adjustable drop.
I measured about 24" from ground to the top of my receiver opening. My current trailer coupler sits around 18.5" level. That puts me right around 5.5" drop -- but doesn't account for sag, etc.
Did you end up going with the 7in?
https://www.amazon.com/Trailer-Hitc...01BYHM91A/ref=cm_cr_arp_d_product_top?ie=UTF8
Do you happen to know your height to the inside top of your receiver hitch? Are you happy with the 5"?
Sent from my Pixel 2 using Tapatalk
