how can i lower my 2001 4 inches in the front
griffo
i want to lower my front end 4 inches on my 01 but i cant find a kit for 2001 that has springs and spindles it seems like they all skip 2000 and 2001. is there any way to lower the front 4 inches?
Trupiano
Registered User
Hometown : Puyallup,WA Stationed : Little Rock,
2010 Ram 2500 6.7L CTD Crew Cab
6.7L CTD
For a 4 inch drop, that's usually more than most people. So you might have to piece together a drop. Like spindles and springs. As all the drops I found so far also stop at 2000. What's the difference in year models as far as suspension?
Ground force has 2" drop coils.
G
griffo
i don't know the differances but i cant even find spindles with out springs.
i was wondering if i could just cut 2 more inches off of 2 inch lowering springs?
G
griffo
i have seen where some people have problems with cutting springs. is that because they are cutting old springs?
will the front end be able to be aligned and stay in alignment?
Trupiano
Registered User
6.7L CTD
People have problems because they either try to heat the spring (don't do that) or cut too much (don't do that either).
As far as the alignment... you should be ok... but I've never done that before, so I can't be certain.
G
griffo
how much is too much and do you think i should cut my old springs or get lowering springs and cut them?
G
griffo
can the springs be taken out and put in without popping the ball joints?
mxmike800
cummins 5.9
what series? i have belltech coils for sale. were on my 3500 dually for 2 months still like new. and yes you need to pop upper ball joint to get the coils out as well as taking out the sway bar links
G
griffo
Its a 1500 I don't think 3500 springs will ride very good on a 1500 might be a little stiff. It dems like a lot of work to keep popping out the spring and cutting a half coil at a time. Wish there was an easier way to do it. Doesn't it mess the ball joint up when your smacking it with a ball joint removal tool?
Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
Not always. When you are doing anything custom it will take lots of trial and error.
Sent from my DROID RAZR using Tapatalk 2
VLG6963
