How long are Cummins diesels good for?
Discussion in 'Towing & Hauling' started by Mpeach1976, Nov 6, 2015.
  1. Mpeach1976
    Mpeach1976 Junior Member
    10
    Nov 6, 2015
    Ram Year:
    1995
    Engine:
    Cummins diesel
    I have a '95 ram 3500 with a Cummins diesel. It has 200,000 miles on it now and I am planning to drive it to Louisiana to haul a pick up back to California. I'm going to have the truck checked out before I go: hoses, breaks, belt...etc... And I've always heard that 200,000 miles is not super high mileage relative to the longevity of the Cummins diesel engine. Is there anything else I should check with that truck since I'll be hauling 2000 miles back?
  2. darthdzl
    darthdzl Senior Member
    826
    229
    Oct 27, 2014
    Phoenix, AZ
    Ram Year:
    2017 Tradesman RCSB
    Engine:
    V6
    If it was taken care if in its previous life, and you continue to take care of it, that engine could easily last half a million miles.
    As for what you should check, the usual things: fluid levels, determine when they were changed, anything loose, any drivability symptoms. I'd recommend having an extra fuel filter on hand (especially if it sat for a while without being driven), as well as some basic tools.
    Beyond that, I'd have to declare my ignorance having not actually owned a Cummins. Others can probably chime in with better advice.
  3. dapepper9
    dapepper9 Senior Member
    22
    4,830
    1,864
    Feb 7, 2013
    Iowa/Nebraska Border
    Ram Year:
    2001
    Engine:
    5.9L V8
    Make sure all your filters are up to date and snuff, so fluids are at proper level (axles, trans, t case, oil, coolant, power steering, brakes, everything). Is be sure coming system works well that's a long time on the road and you don't wanna be on the side thx to overheating.
  4. JUICEBOX
    JUICEBOX Senior Member
    34
    109
    37
    Sep 19, 2015
    Ram Year:
    Engine:
    200K isnt anything to worry about.
  5. 300mark
    300mark Junior Member
    Apr 15, 2016
    Ram Year:
    1996
    Engine:
    5.9 Cummins 12 Valve
    much longer than 200K
    I have a 1996 with automatic and it now has 418,000. I regularly pull my 9,500 pound 5th wheel camper with the truck. I would not worry if yours has been maintained properly. The transmission was rebuilt at 273,000 miles.
  6. Hemipower392
    Hemipower392 Senior Member
    873
    341
    May 8, 2013
    College Station, Texas
    Ram Year:
    Engine:
    I'm missing 2 cylinders
    If you keep up with maintenance, it should last till the end of time
  7. IrocRam
    IrocRam Senior Member
    140
    16
    Apr 6, 2016
    Phoenix, Az
    Ram Year:
    1997
    Engine:
    5.2
    My 2001 that I sold last year had 327k on it with the original motor and still had good compression and even had the stock injectors and ran perfectly. Transmission was rebuilt by previous owner so that had no issues either. I have seen some Cummins with over 500k and still able to pull like the day it came off the lot.
Share This Page
