- Feb 3, 2016
- 3,207
- 3,519
- Location
- The Lonestar State
- 2021 Limited Longhorn CTD HO DRW 4x4
- Cummins 6.7L HO
Hmm , check out my OP , I Removed this to give me more room with the break line .I recently tried this but for whatever reason, I just didn't have enough slack in my brake line and I was only going to add a 1". I am going to take it to my local shop and see if they can get it done. I may have to have the hard line bent or even longer brake lines. Take a look. Majorly bummed.
If your talking about my original post. , Thanks brother I appreciate it. . I try to be over informative because everyone has different past experiences [emoji1303][emoji1303]WOW!! REALLY REALLY WELL WRITTEN! BRAVO FKN ZULU! Hahaha! Honestly though, I feel like I can do this on a weekday before dinner, the way you fully detailed the procedure. thanks again.
Do the Bills yourself if your capable [emoji106]R.L.K., I second ****** 91!! Original post is AWESOME!!! I'm definitely doing these on my own! May let the shop do the Bils though...
Yup I do it's a Magnaflow 24 (Mufflex 24)@Hemi395 , I thought you put an aftermarket muffler on your truck ?
Yes sir , my truck has bills up front at +2.8" and the steel TGC 1.5" Spacers on the back all on stock tires [emoji1360]So I know this is an old thread but those measurements you posted were on stock 275 60 20s after initial install?
Sent from my SM-N920V using Tapatalk
Glad I could help Sir [emoji106]GREAT POST!!!! I followed the instruction and was in and out of the bay in under 45 min.
I wouldn't trust the ones that go on the bottom simply because there's no reliable way to make them lock in. The ones that are on the upper mounts lock in so well it's virtually impossible for it to come out....I see coil spacer that go on top of rear coil and ones that go on the bottom. What the difference?
