Ghost_RAM
Should be there. I'll give you a screenshot here is a moment.Ok. Where in alpha is the setting. Just looked under vehicle config and didn't see anything
Vehicle Configuration 3: HVAC Configuration:
Select:
Dual Zone ATC
Disconnect AlfaOBD app & shut off the truck for a few minutes and you must wait for the Dual Temp sliders to display on the 8.4 radio before proceeding with single zone ATC change.
(Battery disconnect between can speed up the radio/BCM reset for changes, especially with a UAx radio)
Select:
Single Zone ATC
