How To: Cleaning an idle air control valve.
Discussion in '3rd Gen DIY' started by SmokedRam, Mar 3, 2013.
  1. SmokedRam
    SmokedRam Supporting Member
    38
    6,468
    433
    May 1, 2012
    Zephyrhills, Florida
    Ram Year:
    2005
    Engine:
    4.7
    Well, my truck was past due for this, so I figured while doing it, I'd snap some pics and make a brief how to on it.
    First off, some symptoms of a dirty idle air control valve are:
    Engine has a rough idle, might even sound like a miss.
    Engine want to "hunt" an idle speed.
    Engine hard to start, may require pressing the accelerator to get it to crank.
    Stalling at idle.
    Now onto the good stuff. First thing you want to do when messing with any sensor is take the battery cables off the battery.
    [​IMG]
    Next locate the idle air control valve. It is just below and forward of the throttle position sensor, attached to the throttle body with one T25 torx screw. You can plainly see it in the pic below, plugged into the connector with the red tab on it.
    [​IMG]
    Next, disconnect the connector and use a T25 torx bit to remove the screw. Then it will come out of the throttle body. If its never been removed, it might take a little force to remove it. But be careful, as there are O rings to seal it that you don't want to damage. Here is mine removed, notice how YUKKIE it is.
    [​IMG]
    Now, take some carb and throttle cleaner and spray it to remove all the gunk and carbon off of it. DO NOT insert anything into the valve to clean the inside, as you might push back the plunger and then this easy job becomes a PITA and these things are $67 each at Advance. Here's mine all cleaned up.
    [​IMG]
    [​IMG]
    Now, don't go throw it on the truck just yet, let it sit and air dry for about 15-20 minutes. Then you can go ahead and reinstall it. By this time, since you disconnected the battery first, your PCM will be reset after you install it. Now you're good to go.
  2. datan556
    datan556 Junior Member
    33
    Aug 7, 2014
    Ram Year:
    2010
    Engine:
    Would it be roughly the same steps on a 2010 model?
    Truck has recently starting stalling at low speeds and when braking for a roundabout.
    Oil light came on just before stalling.
    Might be the cause right?
  3. daveray9
    daveray9 Senior Member
    594
    87
    Oct 22, 2015
    Ram Year:
    Engine:
    anyone know how the 09+ trucks control idle? They don't have an IAC on the throttle body...
  4. Artnes
    Artnes Junior Member
    36
    Dec 17, 2016
    Ram Year:
    Engine:
    Bump.
    My 2011 is having the exact same issue and shutting off during a low idle at a stop.
    It seems to be more frequent in colder weather as we have had a cold snap recently. -20c or colder lately and it's happen 6 times in 2 weeks
    Sent from my SM-G920W8 using Tapatalk
  5. daveray9
    594
    87
    Oct 22, 2015
    Ram Year:
    Engine:
    Curious myself for my 2012.
    Sent from my SM-G920V using Tapatalk
  6. Drv
    Drv Junior Member
    26
    Mar 14, 2017
    Ram Year:
    Engine:
    How often should this be done?
  7. Vytasb
    Vytasb Member
    54
    Aug 30, 2017
    Ram Year:
    2003
    Engine:
    4.7
    Just did mine. Idle is a bit more stable. Pics don't work, which would have been nice but the text is enough.
Share This Page
