check the owners manual pg 255 for a 2012 model
can be found for download online
cut & paste from my pdf manual:
To reset the oil change indicator system (after performing the scheduled maintenance), refer to the following procedure:
1. Turn the ignition switch to the ON/RUN position (do not start the engine).
2. Fully depress the accelerator pedal slowly three times within 10 seconds.
3. Turn the ignition switch to the OFF/LOCK position.
He forgot to tell you that you had to pull on your left ear lobe twice after you do the above things.
Jay
2013+ yes. OP is showing he has a 2012.You can do this through the EVIC!
