BatTruk
I would still have one fan at each end just to push air through. If you are not pushing the amp near its limits you could be ok...
View attachment 118598 This is how my installer mounted my amps.
All this to push a sub ? What am I missing ?
You can, but then you’ll be running signal, power, and speaker wires through both walls. That opens you up to issues if the wires rub against the edges of the hole. Plus it creates a place for water to get into the cab.
Holy hell that looks techyView attachment 118598 This is how my installer mounted my amps.
Nice set up, I have a similar set up using the factory sub box with a Pioneer sub
What box and sub are you using ?
There is a drainage slot in the front floor of the bed (no water anyway due to the cap) and figured I can go in through the bottom of the cab and put rubber grommets for the wires to go through then seal it with silicone. Figured this way the limited air space behind the seats doesn't hinder it
Or windows open... I can open the windows of the cap as well.. Just figure behind the seats would be no air.. If I'm wrong I'm good with them thereMy only other thought on that is in the summer it might get very warm back there. In the cab you would most likely have the air conditioning running.
Here’s how I have mine set up, small mono amp on a sheet of wood with the seatbelt bolts going through it. Oem 6 speaker setup with a LCi2 coming off the rear signals.
