bought a 2000 Dodge Ram 1500
4x4 short box 5.9L quad cab….. 118k miles
Ive owned 6-8 of these and this is another yellow one I wanna make really nice:
I manage a NAPA store and will be using to promote and sell more products:
Its gonna be a project, but want to install parts and use them to be able to say – this IS what I use!
Please advise how you can help….
Electric cooling fan conversion kit - any suggestions on brand(s)?
Fit towing mirror kit, Oem look, black, power, not heated
Fan control dash knob
Temp control dash knob
FRONT turn signal lamp assy (2) ANZO?
Front headlamp assys (2) Anzo?
Master cylinder reservoir replacement
Yellow caliper paint kit 2
Kit to paint factory wheels – Charcoal Chrome black (4 wheels 16”)
Front molded floor mat kit with center hump (black carpeted)
Premium brake pads Napa ADO
Rear brake shoes Napa
Brake hoses Napa
Best Front Brake rotors Napa
Front Brake calipers and hardware kits Napa
Rear drums Napa
All new stainless steel polished brake lines (Any idea who has them?)
Front wheel bearing hub assy Napa
Front axle ujoints have been replaced
Heater Core needs replaced
AC Hose
AC oring kit
AC receiver dryer
Premium ride shocks – front & rear I WANT THE BEST RIDE
Replacement Front steering stabilizer shock and boot kit
- No towing, or off road – want premium RIDE!
HIGH flow –high output direct fit replacement muffler
Black exhaust tip – 3” inlet / 4” outlet 12” slash
PREMIUM (best) wiper blades Napa
Full set of BLACK lug nuts - extra long
Complete speaker upgrade – Hybrid Audio only
Stereo Amp install kit (Yellow wire) Monster?
Apline (or similar) stereo
Treo amp kit
12/16 Volt battery
Build yellow battery cables complete
Gold battery terminals with volt meter in 2 positives..
Dynamat noise deadener kit
New Starter Black chrome
HELP!:
New alternator black chrome – 16 volt upgrade (need help)
- HAS anyone bypassed the regulator in the ECM and used an EXTERNAL
regulator - so I can install an Adjustable regulator to charge my 16 Volt
battery. (The my battery has a 12v and 16v terminal.
The oem neg cab has three wires, one small one to frame, and two other very small body grounds.
Im going to ground my 16v battery with a large ground to frame, and to medium grounds to the body / engine.
The oem POS cable has two wires, one to the fuse box / power supply, and one larger one going across to starter terminal.
Im planning to run a Larger YELLOW fine strand cable to the starter from the 16 volt battery terminal.
Im planning to run a MED RED fine strand cable to the power supply from the 12 volt terminal on the battery.
(once I confirm the ECM & injection system can handle the 16v+ - Id like to convert the whole truck over.)
All of the electric motors, etc will handle it, just need to worry about other things……. first
I know the starter will be faster, and last longer…… I know if I can run the ignition on 16v I’ll get more power and performance….
SO, any ideas on getting an alternator mounted on this truck, to charge the 16v AGM battery ?????
Approx 19.25v max is idea. Im thinking 110 – 130a will be enough, even with amps, and added lighting.
Current load will be OEM, but will add a stereo amp on the 16 volt side in the future.
Maybe instructions to wire in a 911-02r?
Im ok if the battery light comes on and stays on….)
New engine belt Napa
Engine idler and tensioner Napa
Upper rad hose Napa
Lower rad hose Napa
New Water pump Napa
Bypass hose Napa
Heater hoses – premium Napa
200 Degree thermostat w/ gasket Napa
100%
Synthetic engine 5w30 Napa or AMSoil or
and trans ATF+4 AMSOIL
and differential oils synthetic
power steering fluid – synthetic
premium antifreeze
trans filter kit with PREMIUM pan gasket NAPA
inline transmission filter kit with filter NAPA
inline powersteering filter kit NAPA
Dual engine oil filter conversion kit & 1459 (2) Napa filters or transdapt complete kit?
The very best distributor, cap, rotor, updated coil and yellow wires w/ matching plugs – Perlux, Accel, MSD, Echlin Expert?.... Is there a complete upgraded distributor for these?
PCV Valve w/ grommet
BEST o2 sensors?????
Bully bar (black)
Vision Lights for above
Premium Oem fog light replacements (sport)
BRIGHTEST headlamp bulbs available (sport pkg)
Premium LED (plasma) for interior and exterior bulbs
Paint valve covers and replace gasket: Felpro
Front and Rear Diff cover gaskets
Needs windshield
Paint Clear front door ventvisors only (low profile – in channel)
P2656016 tires (4) a/t like maxis ma-v1 - Best ride
Yellow Loom kit
6 Cans of aerosol mathching paint
Pre cut Dark tint kit side and back kit 20%
Oem style bed cabs side and tailgate plastic
Headlight covers smoked
Molded front & LONG rear splash guards like Mopar version
rear bumper roll pan for use with a factory receiver hitch
Yellow spray in bed liner kit
SRT10 look hood scoop (wade?)
OEM look wheel flares or street flares (2 pair)
Tailgate assist shock kit
Directed remote start, keyless entry, via smart phone
Energy suspension complete bushing kit:
Seat heater kit
Yellow gauge / dash insert kit
I have to lower the front end 2-3 inches!!!!!!!!!!!!!!!! ???
Black decals for all products…
I have spoiler, will need RAM decal set
I WANT a sticker package for every item / brand we install, and a classy way to install them …..?
It’s my fave - yellow….!
EMAIL ME AT [email protected] with your comments and suggestions; and tech help.... and if you have had bad experience with some things...?
Brake hoses Napa
Rear drums Napa
AC Hose
AC oring kit
AC receiver dryer
Treo amp kit
12/16 Volt battery
HELP!:
Upper rad hose Napa
Lower rad hose Napa
New Water pump Napa
Bypass hose Napa
100%
premium antifreeze
Bully bar (black)
Needs windshield
Yellow Loom kit
Seat heater kit
