I think my fuel pump went out
Discussion in 'Engine & Performance' started by e_hartzell17, Jan 6, 2017.
Sponsored By: Moe's Performance
  1. e_hartzell17
    e_hartzell17 Senior Member
    20
    110
    10
    Jul 26, 2016
    Ram Year:
    2001
    Engine:
    5.2 318
    Ok so I started the truck and let it idle for a rough 30 mins or so then I got in it hit the skinny pedal on the right a little and boom she died, when I went to go crank it it didn't start back up, so I left the key on and got out to hear like a hairdryer sound coming from my fuel tank and I'm pretty sure my fuel pump went bad not positive though. Any body ever have this happen if so I could really use an explanation haha.
  2. dudeman2009
    dudeman2009 Senior Member
    22
    1,457
    166
    Feb 9, 2016
    Lansing, Michigan
    Ram Year:
    2001 1500 Sport with enough electrical modifications to make my brain hurt
    Engine:
    Magnum 360
    Is their fuel in it? The gauge may be wrong.
    Try hitting the tank with a hammer, or getting a fuel rail pressure test kit, you can rent them from autozone.
    It should only prime for 5 seconds or less, usually if it tries to prime longer than that, it indicates a problem. Is there any fluid leaking?
  3. dapepper9
    dapepper9 Senior Member
    22
    4,831
    1,866
    Feb 7, 2013
    Iowa/Nebraska Border
    Ram Year:
    2001
    Engine:
    5.9L V8
    Whine from the tank is a good thing. It means the pump is at minimum trying to work and is getting signal. If you hear it whine, check rail pressure for about 50psi +/- 2psi. Good pressure, pump whines, likely going to be spark
    Yeret likes this.
  4. texasrebel
    texasrebel Member
    21
    85
    23
    Jan 2, 2017
    Ram Year:
    1995
    Engine:
    5.9 Magnum
    Mine went out about a year ago. Found easiest way to access it since it had a full tank, was to lift the bed. Dropping a full tank isn't fun.
    Sent from my SAMSUNG-SM-G870A using Tapatalk
  5. e_hartzell17
    20
    110
    10
    Jul 26, 2016
    Ram Year:
    2001
    Engine:
    5.2 318
    Well luckily for me I'm under a 1/4 tank but it's weird cuz about 2 hours after I though she went out, it started right back up no problems
  6. texasrebel
    texasrebel Member
    21
    85
    23
    Jan 2, 2017
    Ram Year:
    1995
    Engine:
    5.9 Magnum
    Hm. Kinda odd. Might still want to get someone to test the system.
  7. e_hartzell17
    20
    110
    10
    Jul 26, 2016
    Ram Year:
    2001
    Engine:
    5.2 318
    Yeah for sure another good thing though is wishing the next few months I'm putting a turbo setup on the truck so new fuel pumps going in anyway
  8. texasrebel
    texasrebel Member
    21
    85
    23
    Jan 2, 2017
    Ram Year:
    1995
    Engine:
    5.9 Magnum
    Turbo setup? You have my interest.
  9. e_hartzell17
    20
    110
    10
    Jul 26, 2016
    Ram Year:
    2001
    Engine:
    5.2 318
    Lol yeah gonna be running a remote mounted hy35 cummins turbo tuned with sct with a warlbro 225 fuel pump, ford cobra 39# injectors, 8psi wastegate and a mild comp cam
  10. texasrebel
    texasrebel Member
    21
    85
    23
    Jan 2, 2017
    Ram Year:
    1995
    Engine:
    5.9 Magnum
    You got any idea what kinda power boost your gonna get? IIRC, the stock internals can only handle around 9lbs up top before the heads start floating and around 12 on the bottom end. Got a build thread for this?
Share This Page
