I think my fuel pump went out
Discussion in 'Engine & Performance' started by e_hartzell17, Jan 6, 2017.
Sponsored By: Moe's Performance
  1. e_hartzell17
    e_hartzell17 Senior Member
    20
    110
    10
    Jul 26, 2016
    Ram Year:
    2001
    Engine:
    5.2 318
    I was thinking somewhere in the +100hp range started a thread called 5.2 magnum turbo just kinda threw around the idea not taking it seriously cuz let's face it if the motor won't blow the tranny will but decided to say fuck it and went for in bought everything I will need now just waiting for the time to do it
  2. crazy_luck
    crazy_luck Senior Member
    1,114
    748
    Nov 9, 2014
    Minnesota
    Ram Year:
    Engine:
    Try cycling the key from OFF to RUN a few times - it will pressurize the system. If it starts and stays running, you have a pressure regulator issue or a plugged filter. If it stalls out after a few minutes, the pump is dying. Drove my last 2nd gen with a failing pump and regulator for 6 months - had to cycle the key about 10 times every time I started it (regulator). If it sat at idle, it was fine but if I floored it, it'd die (pump).
    Also, running as low as you are on fuel, that might be part of you problem - your gauge may be off to the point you don't actually have enough fuel.
    mda8569 likes this.
  3. e_hartzell17
    20
    110
    10
    Jul 26, 2016
    Ram Year:
    2001
    Engine:
    5.2 318
    Never even thought about that
  4. texasrebel
    texasrebel Member
    21
    85
    23
    Jan 2, 2017
    Ram Year:
    1995
    Engine:
    5.9 Magnum
    I'll check it out. I'm curious to see how it'll turn out.
    Sent from my SAMSUNG-SM-G870A using Tapatalk
  5. e_hartzell17
    20
    110
    10
    Jul 26, 2016
    Ram Year:
    2001
    Engine:
    5.2 318
    The day I got the turbo in the mail
  6. texasrebel
    texasrebel Member
    21
    85
    23
    Jan 2, 2017
    Ram Year:
    1995
    Engine:
    5.9 Magnum
    Ooooo. Love that color. You oughtta post a build thread somewhere for the whole truck. Thing looks sweet.
  7. e_hartzell17
    20
    110
    10
    Jul 26, 2016
    Ram Year:
    2001
    Engine:
    5.2 318
    Thanks man took a while to get it there but it was all worth it
  8. texasrebel
    texasrebel Member
    21
    85
    23
    Jan 2, 2017
    Ram Year:
    1995
    Engine:
    5.9 Magnum
    1500 or 2500? Wheels make it hard to tell, but I've never seen a 318 in a 2500.
  9. e_hartzell17
    20
    110
    10
    Jul 26, 2016
    Ram Year:
    2001
    Engine:
    5.2 318
    1500 with a 3.5" leveling kit up front and stiffened suspension in rear
  10. texasrebel
    texasrebel Member
    21
    85
    23
    Jan 2, 2017
    Ram Year:
    1995
    Engine:
    5.9 Magnum
    Nice. This is mine. 1500 4x4 with the 360 and a 3 inch lift on 33s. Really want to repaint it a green like that or a nice orange.
    [​IMG]
Share This Page
