If I dont like MUFFLEX...
U&A
U&A
2016 3500 SRW
6.4 HEMI
So cutting the resonator off made a noticeable difference for sure. I would say more than just a “noticeable difference” the truck sounds almost like it has different exhaust system on it. Give it a little more “raspiness” and a lot deeper pronounced hemi rumble....but, Taking the resonator off does do what you would assume, it creates a little bit of drone around 2200-2,500RPMs as well as a very slight notice of drone around 1700 RPM. Doesn’t bother me.
Now this truck sounds
like I wanted it to.
mohemipar
2017 Laramie
6.4 Hemi, 4.10's
Did you run a custom pipe all the way out the back or dumped it around the axle... or just left the pipe cut off?
U&A
U&A
2016 3500 SRW
6.4 HEMI
For now it’s cut off as close as a sawsall would let me get to the resonator and that’s it. I orderd a nice tip from Nick to put on it. Just for a little better look and to add a few more inches to help it get out from under the truck. Not sure how well the tip will fit on because there is a bend close to the cut off point. Nothing a little weld cant fix though.
U&A
U&A
2016 3500 SRW
6.4 HEMI
Yup definitely louder all around. And when the wife was in the truck this evening she INSTANTLY noticed it was louder.
popjim52
Baltimore,MD
2014 Tradesman 2500
If you don't like Mufflex....... you would be a normal person... :)
U&A
U&A
2016 3500 SRW
6.4 HEMI
Ir sounds great without the resonator
U&A
U&A
2016 3500 SRW
6.4 HEMI
This picture is for PMCFERRON because i cant post pics in “PM’s”
Sir.
It is fixable just slightly bent. Ill get a price for you this week.
silver2door
hello,new guy here, I replaced my restrictive muffler (and flapper valve) with a walker 21467 resonator,short piece of 3.5" pipe and a couple of universal hangers,total cost less than $100.00, nice old school glasspac sound with no drone. pipes were not bent and lined up great, maybe change the angle of the tailpipe a little but not noticeable. Cheap alternative for folks on a budget.
silver2door
Just to clarify I kept the factory resonator in place so with 2 resonators there isn't any drone.
MJockey
TENNESSE
Hemi 6.4L
Can you grab a photo of it on the truck. The stock muffler has a offset so I trying to figure how it could line up. Thanks
Reactions: U&A
U&A
U&A
2016 3500 SRW
6.4 HEMI
Pictures would be great
silver2door
No problem at all. My son will be home this wknd and I will ask him for help to post them up. when I bought the resonator and pipe I thought I would have to bend the pipe, but when I did a trial fit I was surprised that it bolted right on with only a slight change in the tail pipe angle.
busterbrown
Detroit, MI
2017 Ram 2500 Megacab Laramie
Video clip of the exhaust note would be nice too! ;)
U&A
U&A
2016 3500 SRW
6.4 HEMI
Thank you for sharing sir
