Incoming air door motor knocking
5 speed
Flatistan
2016 Ram 2500 Crew
so I had knocking under the dash and saw some videos and thought it was the blend door actuators. but when I pulled out the center console and turned the key, I discovered the noise is coming from the passenger side. I pulled the glove box and it appears that above the fan motor is this weird shaped door, like an umbrella and the motor that drives is is where the knocking is coming from and i can see it jumping. So, the question is, where is it and how do you get to it? might I get lucky and it be the same part no as the other actuators (I bought one of those). Do I have to pull the fan or exactly what, does anyone know? Your help is always appreciated!!!
