Inez 4/6 review
DARKNHT
Georgetown, IL
Ahh I’m just gonna go with some QA1s TN513s and call it a day...
Quicksilver337
South FL
2016 Ram R/T
I called Rancho about the RS999215 (fitment for a 2000 IZUZU Trooper 4WD) shocks they told me it wouldn't work as the mounts don't fit our trucks. Yet the INEZ kit uses the 9/16" mount as well I would assume that the RS999215 has on it. So does the INEZ shocks come with new hardware, or did you re-use the OEM hardware?
Correct... the Inez rear shocks that comes in their kit is modified to fit our truck. They are not plug and play if you buy them on your own. I've replaced the rubber and sleeve to fit.
You can buy any shock brand as long as they have the specs (Compressed Height & Extended Height)
I'm ordering a 5/7 drop for my 2012 express, and currently have a belltech 2/4 drop. When I put my current kit on I got rid of my stock springs because I thought I would never use them again... Now I apparently need to use them again and don't have them. Can I use my belltech springs? Also I currently have stock wheels and tires, and can't tell if I'm going to have to go with a shorter tire to clear the fender/ fender liner. Any input is much appreciated!
ramittome
Gonzales, LA
Had a 4/5 McGaughy drop on old truck with stock 33" tires. Rubbed a huge hole in fender liner.
Went with a 4/6 Inez drop on this truck with 31" tires. No running issues at all. Same exact rims.
The Belltech front springs along with the control arms will give you a 6" drop up front. Can always see if someone on here is selling their stock springs.
Also, you can buy just the front control arms, rear brackets, and rear shocks from Inez and save you some money because it comes with Belltech rear springs as well. You just cut them down to the size you want because they send you the exact 4" drop springs you have now.
Quicksilver337
South FL
2016 Ram R/T
if your going with the 5/7 drop you would need to cut the factory front springs. Your best bet is to buy a set of 1" front drop springs. That's what I did... got a set of Crown Suspension 1" front springs
The Crown springs are 1" lower than the factory springs
T
Twistedshadows
I believe you can order the a arms for different heights so of you wanted to use the belltech springs just get the a arms for a 2 inch drop not a 4. I don't rub the fender liners with my stock 22 (maybe a little on larger bumps) what I do rub is the sway bar at full lock because it sits to high even with the f150 end links. But your mileage might vary
Quicksilver337
South FL
2016 Ram R/T
The Inez Hotrod arms are all the same for the Ram if you want to do a front drop lower than 4" you have to cut or replace the front spring. The front arms are meant to be used with your stock front springs giving a 4" drop. If you want a 5" drop cutting the stock springs or replace them with a 1" drop spring.
T
Twistedshadows
Update
So I finally got around to doing the front bump stops. Truck rides a lot better I didn't realise how often I was hitting the factory ones. But now i rub the top of the inner fender liner on large bumps and fast turns.
In the rear i cut the cups out and dropped it All the way down to see where the shocks bottom out. The beilstiens bottom out with 1 inch between the axle and chassis. I ordered a set of one inch bump stops with the to bolt hole tabs because there's no way to use the bump stop that has the stud because the factory bracket is boxed off. I'm gonna put a 1\4 inch plate under the new bump stop so I don't bottom out the beilstiens especially since I cut another coil to get the full 6 inches in the back and there is roughly about 1 1\2 inch of travel back there.
Anyways just really wanted to let people know that you can run the beilstiens shocks in the back and get full travel out of it with a 1-1 1\2 inch bump stop in the rear. And the springs are still long enough not to fall out at full drupe.
6speed4.7
Winnipeg
Update
Just curious, did you happen to measure the rear shock eyelet to eyelet with the bumpstop out?
I'm just getting around to doing the rear kit, and im having trouble getting the right most new mount on. It's hitting the knuckle (not sure what else to call it) of the linkage. Has anyone had this problem? Any solution?
Haha just kidding. Realised I was supposed to put the linkage in the other hole :)
mighty noid
Culver City
Hydro Blue 2018 4x2 Sport Crew Cab
Ok after reading all of these posts.
I will be ordering this kit.
Moog F150 links.
New adjustable Spohn Rear Panhard Bar.
Bump stops will be either removed or cut in half.
I will hold off on the rear shock upgrade unless it isn't that good of a drive... then I would get those Q1's..
Thank all of you for this great info...
mighty noid
Culver City
I just ordered the kit and everything else on my list yesterday... should be on the truck in about 3 weeks.
Eddywardo
Houston
can you give me the part # or link me to the f150 end links please? thanks in advance !
WadXpress
HEMI
I read through alot ot this a few times. So did someone find a qa1 that fit or not? What other shocks are you guys using instead?
ICEBOXx
Ft. Worth Texas
my kit works great ,, the only problem is the upper bushions are very noise all the time sounds like its about 100 years old .
anyone have a fit for that ?
mighty noid
Culver City
Have you given them a call yet??? Maybe they can send you another set?
