Issues with factory front end link removal
J3FF3RSON
Louisville, Kentucky
2014 Ram R/T
Hello everyone,
I'm currently in the process of replacing the Hellwig front sway bar, and I wanted to put new F-150 end links on the front, however I am having a hard time removing the bottom bolt from the end link. I'm holding the top of the end link with a wrench and using a ratchet to remove the bolt, but the bolt turns with some resistance, but the bolt isn't moving. Is there something else keeping this bolt from coming out?
I appreciate the help!
moregrip
I used vice grips on the upper portion of the stock end link, mine became sacrificial.
J
J3FF3RSON
2014 Ram R/T
The top portion doesn't move at all when I'm spinning the nut at the bottom because my wrench is holding it firm just under the top threads. Should I be holding the end link at a different location?
jettajam1
CA
2012 and 2019
You will need to hold the lower hex when loosening the lower nut. I encountered the same thing and right before I took a sawzall to it....I noticed the lower hex. I used a ratcheting box end wrench for the nut and a 5/16? box for the hex.
Here they are removed (notice the lower hex)
And the Mevotechs I installed
J
J3FF3RSON
2014 Ram R/T
That picture is actually very helpful! Alright, lets see if I can get these off before dark!
Thanks for the responses!
jettajam1
CA
2012 and 2019
Keep us posted on the outcome
J
J3FF3RSON
2014 Ram R/T
Quite possibly the most frustrating design I have ever seen in my life. My 3/4 12 point box wrench wouldn't hold the recessed bolt without slipping as i turned the 5/16 hex at the bottom, while no other size I had worked on it. My Flex Heads also wouldn't fit up there.
So they are still on the truck until I can source a tool that will work in that recessed hole, while simultaneously allowing another socket / wrench for the bottom hex bolt.
jettajam1
CA
2012 and 2019
Frustrating is right....hence my sawzall comment. I was able to get a 19mm wrench in there at an angle and wedge it up against the frame just enough to hold the nut stationary, then started turning the hex (it was a *****) but it worked.
Good luck brother,
J
J3FF3RSON
2014 Ram R/T
Found a way to take that thing off. I went down to Sears and found a Max Access Rachet which allows the threaded part of the bottom to slide through the ratchet, keeping access to the bottom hex.
Tools I used for that bottom bolt:
- 1/4 Inch Drive Ratchet
- 6 inch 1/4 inch extension
- 5/16" Socket
-3/8 Inch Drive Max Access Rachet
- 3 Inch 3/8 inch Max Access Extension
- 18 Inch, Max Access Socket
See the pics below:
grozier
Independence mo
You say put a F-150 part on a ram?
Sent from my SM-G935T using Tapatalk
moregrip
I put the vice grips around that rubber boot, hence the sacrificial part
Gary's Hemi
Walker, La
- 5/16" Socket
See the pics below:
Thats what I used to take the links off. Works perfect. Always comes in handy to have a good selection of tools.
J
J3FF3RSON
2014 Ram R/T
What a hell of a difference up front. It's firm, and incredibly responsive in turns. The only reason I'm getting any lean at all is because of those Belltech garbage shocks - which I will be soon replacing with QA1's. This was well worth the energy to replace fellas, and I hope anyone looking to do this mod will see this thread before taking on the task.
However, I noticed that this sway bar is now very close to the tie rods bars. And I mean by close, I can only stick my fingers between the sway bar, and the tie rod. The Hellwig also appears to be on the end links at an angle, and not straight, however, they are tight. I couldn't seem to get the bar lined up like the factory bar at any angle, and I want to verify that this is normal.
Gary's Hemi
Walker, La
So your endlinks are at an angle pointing in when mounted to the bar? Mine were like that.
J
J3FF3RSON
2014 Ram R/T
This is what I'm looking at on both sides. See how close the Tie Rod is as well.
I doubled up the cups between the center shaft and the cups between the shaft and rubber bushings. I utilized the cups off the original endlinks. Spaces the bar up slightly,not much but enough to help the clearance issues.
Gary's Hemi
Walker, La
Yea my endlinks were at an angle like that when I installed the f150 links. I found that them being at an angle made the truck rock from side to side too much when hitting a bump so I reinstalled the factory links & the side to side motion was gone. The f150 links did help alot w/ body roll due to releveling the bar but the side to side motion just wasnt for me. The links are supposed to be straight up & down, idk what exactly the effect of them being at angle causes but I couldnt get used to it
J
J3FF3RSON
2014 Ram R/T
I'd say that I could easily use the poly bushings that came with the F-150 end links to make it a little stiffer. May end up going back to factory links, I'll update everyone.
BTW, did you happen to experience any failures with your factory end links with the Hellwig on it?
Dubstep Shep
Houston
2014 R/T
Easiest way to do it is put weight on the wheel when you loosen and torque down the links. The weight of the truck on the joint keeps it from spinning if you use an impact.
radikio
