Issues with factory front end link removal
Discussion in 'Lowered' started by J3FF3RSON, Dec 30, 2016.
  1. moregrip
    moregrip Senior Member
    536
    138
    Apr 19, 2015
    Ram Year:
    Engine:
    I put the vice grips around that rubber boot, hence the sacrificial part
  2. J3FF3RSON
    J3FF3RSON Senior Member
    192
    59
    Feb 16, 2015
    Louisville, Kentucky
    Ram Year:
    2014 Ram R/T
    Engine:
  3. Gary's Hemi
    Gary's Hemi Senior Member
    560
    208
    Sep 19, 2010
    Walker, La
    Ram Year:
    Engine:
    Thats what I used to take the links off. Works perfect. Always comes in handy to have a good selection of tools.
  4. J3FF3RSON
    192
    59
    Feb 16, 2015
    Ram Year:
    2014 Ram R/T
    Engine:
    What a hell of a difference up front. It's firm, and incredibly responsive in turns. The only reason I'm getting any lean at all is because of those Belltech garbage shocks - which I will be soon replacing with QA1's. This was well worth the energy to replace fellas, and I hope anyone looking to do this mod will see this thread before taking on the task.
    However, I noticed that this sway bar is now very close to the tie rods bars. And I mean by close, I can only stick my fingers between the sway bar, and the tie rod. The Hellwig also appears to be on the end links at an angle, and not straight, however, they are tight. I couldn't seem to get the bar lined up like the factory bar at any angle, and I want to verify that this is normal.
  5. Gary's Hemi
    560
    208
    Sep 19, 2010
    Walker, La
    Ram Year:
    Engine:
    So your endlinks are at an angle pointing in when mounted to the bar? Mine were like that.
  6. J3FF3RSON
    192
    59
    Feb 16, 2015
    Ram Year:
    2014 Ram R/T
    Engine:
    This is what I'm looking at on both sides. See how close the Tie Rod is as well.
  7. Wild one
    Wild one Senior Member
    713
    214
    Jan 17, 2016
    Ram Year:
    Engine:
    I doubled up the cups between the center shaft and the cups between the shaft and rubber bushings. I utilized the cups off the original endlinks. Spaces the bar up slightly,not much but enough to help the clearance issues.
    J3FF3RSON likes this.
  8. Gary's Hemi
    560
    208
    Sep 19, 2010
    Walker, La
    Ram Year:
    Engine:
    Yea my endlinks were at an angle like that when I installed the f150 links. I found that them being at an angle made the truck rock from side to side too much when hitting a bump so I reinstalled the factory links & the side to side motion was gone. The f150 links did help alot w/ body roll due to releveling the bar but the side to side motion just wasnt for me. The links are supposed to be straight up & down, idk what exactly the effect of them being at angle causes but I couldnt get used to it
  9. J3FF3RSON
    192
    59
    Feb 16, 2015
    Ram Year:
    2014 Ram R/T
    Engine:
    I'd say that I could easily use the poly bushings that came with the F-150 end links to make it a little stiffer. May end up going back to factory links, I'll update everyone.
    BTW, did you happen to experience any failures with your factory end links with the Hellwig on it?
  10. Dubstep Shep
    Dubstep Shep Senior Member
    2,235
    491
    Aug 4, 2014
    Houston
    Ram Year:
    2014 R/T
    Engine:
    Easiest way to do it is put weight on the wheel when you loosen and torque down the links. The weight of the truck on the joint keeps it from spinning if you use an impact.
Share This Page
