Zinnmaster
Long story short. My son just bought a 08 ram 4.7 with 85000 miles. Had it about a month and it all fell apart. I get a call from my son saying the truck died while on the freeway. He said engine light came on truck got hot and was pouring antifreeze from the over flow tank. Got the truck towed home and started diagnosing the problems. Obd reads p0117. Tempature control sensor low voltage. Ok. Also I noticed the water pump bearing was rattling. I was worried he blew a head gasket or cracked the head. From the over heating Checked the oil and it looked clean. Oil change was done when he got the truck. So we replaced the tempature sensor. New water pump. And a new battery. After we got the truck together it started up just fine. We let it run to see if it would over heat again. It did the opposite. The truck really never got hot. Tempature outside was in the mid 30s. So I figured the thermostat is stuck open. Replaced thermostat and new coolant. Put truck back together again and went to start it. Now it will start for a second then die. Won't run, rough idel if it does run for a few seconds. I start it and give it has and it misfires until 3000 rpm and the roughness goes away. Foot of gas pedal rough idle the dies again. And the red light comes on dash. The electric throttle control light stays on. New engine light. We scan it now reads p0300. Multiple cylinder misfire. And heavy white smoke from exhaust. So now I'm lost. I think we have a bad head and I stopped throwing money at it till we know what's wrong.
Any one wanna confirm my diagnossis before it gets towed to a mechanic?
