Key not turning
joepizuro
Magnum v10
Got a 95 Ram 1500 and lately the key won't turn unless I take it out and flip it. Now it takes me 4-5 tries with wiggling the key and pushing it in and out.
I know a new ignition cylinder thing is $60 so I was wondering if anyone had suggestions? I was thinking of making it like my buddies truck where it didn't require a key to start. Just turn it and it turns on. Heh.
Micchi
West Lawn, PA
5.2L
Key may be worn out causing the pins to not line up properly.
You could wire it like your buddies if money's an issue but that does leave your truck vulnerable cuz anybody could get in and start it.
reefguy89
laurel de
had this happen on an 02 dodge work van used some graphite spray on the key and in the cylinder also. It help for alittle while.
J
joepizuro
Magnum v10
Oddly my key started working perfect again and I never did anything to it...
J
joepizuro
Magnum v10
Actually I turned my key today and it felt like my truck died for a split second. Then tried again and it started no problem. It's happened twice so far and the battery seems fine...
txram956
