Kleinn Train Horn Kit Installed
sparky300
I've finally finished installing a RAM1500-230 onboard air system with triple train horns from Kleinn Air Horns on my 2011 Ram 1500 SLT so I thought I'd share it with you. It's a vehicle specific kit as it includes all hardware, brackets, connectors, wire, relays and detailed instructions. The whole kit mounts to the front frame just behind the bumper and is virtually unnoticeable. An accessory kit that includes a 1/4" quick disconnect and 20' coiled air hose and chuck with bag was also included.
Overall, a very well engineered system and the triple horns are loud as hell. I chose to keep the stock horn and run a separate circuit with a piggyback fuseholder from circuit M33 to power both the compressor relay and horn solenoid. The compressor is controlled via the 30A relay and a pressure switch that is only powered when M33 is energized with the ignition on.
I have no affiliation or interest with Kleinn Air Horns.
Compressor mounted
Compressor and tank assembled
30A Fuse and relay installed
Horns installed
Compressor and tank installed
sparky300
sparky300
More install pics...
Piggyback fuseholder
Compressor inlet filter and air quick disconnect fitting
Compressor motor connections
Horn rocker switch
MADDOG
Out Exploring Arizona
Nice looking installation. I soooo want to do this.
chrisp2493
Always Modding
Warren, OH
392 Hemi
Yeah my wife said these were stupid until I told her you could use them on people who cut her off in traffic. Now she wants one lol
sparky300
sparky300
Thanks fellas. I wanted to do this to my F150 years ago when I had it but never did, I was determined to pull the trigger on a kit when I bought the Ram.
It takes considerable restraint to avoid using it unnecessarily it like a hooligan but, I will say that it DOES get a person's attention when it's used in a...ahem...responsible manner. The convenience of having a portable, ready air source ain't bad either. I've already used it for some poor souls at work that had flat tires in the parking lot.
Will post video of it in action this weekend.
If anyone has install questions, I'd be happy to oblige.
S0CAL
US Marine Veteran
The Lonestar State
2021 Limited Longhorn CTD HO DRW 4x4
Cummins 6.7L HO
Sub’d
WilliamS
Tampa FL
Looking the kit up and that brings up a whole different bracket and lay out. Im trying to figure it out but that is behind the front bumper mounting on the horns.
sparky300
sparky300
Correct William, the horns mount to a bracket that bolts to the inside of the left frame nose and the compressor/tank is mounted in the same way but on the right side.
I was skeptical at first that there was enough room but Kleinn did their homework and everything is pretty well protected from damage (with exception of a head-on collision) as everything sits at frame level behind the bumper.
WilliamS
Tampa FL
Ive installed a few Klein systems and they are usually tight as a drum but they were F-150s so the compressor was on the frame rail under the passenger door, and the horns were under the bed in front of the axle.
The picture on the Klein website looks amazing compared to what you get. It looks like 1 solid bracket that goes between the rails with everything all on 1 part!
sparky300
sparky300
Not sure why, but that photo from their website is not representative of the new mounting system that I received, they now use two separate brackets.
Agreed. I could definitely buy all the components included in their kit cheaper myself but I'd still have to engineer, fab and powder the mounting brackets. For the money, they include it all and all I had to do was spend a Saturday wrenching.
Casper
U.S. Navy (Ret.)
Springfield, VA
5.7L
Could have used that on my morning commute today. @$$wipe in an Audi rockets up in a merge lane on the right and wizzes in front of me with inches to spare while a Doofus in the left lane is coming over into the same spot. If I hadn't eased up on the throttle when I spotted @$$wipe and Doofus converging it would have been a three way fender-blender.
Somehow a single digit salute just failed to express my anger and frustration.
A train horn definitely would have gotten my point across!!!
sbarron
Wasilla, Alaska
I have a set (HK-9) that I've yet to install. Still trying to plan where to put it all.
Jrod
USAF 1997-2008
Virginia
2016 Sport
Jesus, just when I thought I had all my must have mods sorted out.... This is now in my top 5.
I95 northern VA and snowflakes around DC will will soon be triggered again!
ramportin1
Sickest member here
Oregon
MY THOUGHTS EXACTLY!!! lmao
This would get me in trouble... everywhere... anytime the key was in the ignition.
Eeeeeeeexactly lol I know me, I would have no control lol
S0CAL
US Marine Veteran
The Lonestar State
Cummins 6.7L HO
wonder if they have alternative install location. I am going to put a Warn VR12000 behind my bumper. :-(
Cdrm03
Fall River
Cummins
I have the 734 kit for my 2018 RAM 2500. Hoping to get it installed in the next few days.
Grant211
I wanted this until my friend said “if the guy behind you honked at you with train horns on what would you do?”
I said I would either brake check him or something stupid to retaliate back.
He said..:eek:hh road rage I see...
I said yeah I guess so.
With that said. I’m not getting a train horn. lol.
