leak water passenger side
michelram
need help please leak water passenger side
hello i have a dodge ram 1500 2006 I will strain the water through the passenger side
the ladder handles by screws water goes ...
can help me have more than two months with this problem
usaf2006
Augusta, GA
Please dont take this the wrong way but im not sure what you mean. Can you post pictures or try reexplaining it?
M
michelram
pictures water leak
the water from the handle (screw) goes out
usaf2006
Augusta, GA
Check the water drip rails. If the channels running down the door jams by the windshield and where the door latches to the truck are clogged then it would force the water else where. Very common problem in 07 to 2009 jeep liberties. Leaks in the same spot.
M
michelram
leak water
and I brought the car to a auto glass store the water doesn't go through the windshield
and seal the third brake light urethane and water problem continues
thanks for the help
M
michelram
the rail were sealed with urethane all screws and still have the problem
usaf2006
Augusta, GA
Sorry not sure what the issue is then. Hopefully someone else will help.
jadocs
Take it to the dealership. It's a known problem in some trucks.
M
michelram
no warranty is 2006 if the dealer will charge me a lot of money going someone with this problem.
2006 dodge ram 1500 4doors
RonJon '06
Southern Minnesota
Do you have cab clearance lights? A sunroof? If you have a sunroof there is a drain line that goes through the a-pillar that can leak. If you've sealed the wind shield and 3rd brake light then I would check the door seal. Pull it out and then silicone the holes when you re install it. There have also been a problems with leaking at the rear roof/side body panel seam, that would be harder to fix.
