Hey nick I put the front leveling kit on. With my other 20s and 35s!HID's are the way to go. I put the retrofit source Morimoto HID kit in my projectors in my 1027 RAM Power Wagon. They work great and are a Mopar specific kit with everything needed to make them plug and play so they work with our CANBUS system.
We offer these kits and of course offer a discount for the members here. PM me if your interested in a quote with your vehicle info and shipping address.
Yeah I'm trying to figure out what all I need to add 1 in to the rear now. If it's links and panhard bracket with longer springs or not.Looks great leveled out!!
Sent from my SM-N950U using Tapatalk
Yeah I won't do a spacer it will be springs.Depends, you can go cheap with just a spacer on the rear coil OR you can do what you mentioned which is probably the better option but obviously more money. depends on how much you want to spend i guess. I am not 100% sure on what would be necessary to change. I could ask Don Thuren what he recommends of you like.
My issue is that I want the same spring capability meaning I'm able to tow my TT and 5th wheel without the rear sitting lower than the front. I may just have to do air as much as I don't want too.Depends, you can go cheap with just a spacer on the rear coil OR you can do what you mentioned which is probably the better option but obviously more money. depends on how much you want to spend i guess. I am not 100% sure on what would be necessary to change. I could ask Don Thuren what he recommends of you like.
Air is awesome! I have an airlift system for towing my mobile detailing setup and 37ft camperMy issue is that I want the same spring capability meaning I'm able to tow my TT and 5th wheel without the rear sitting lower than the front. I may just have to do air as much as I don't want too.
What system do you have? Pictures of the install or completed install?Air is awesome! I have an airlift system for towing my mobile detailing setup and 37ft camper
Let me check. Im sure I do. Give me a fewWhat system do you have? Pictures of the install or completed install?
Very nice! I'm thinking that I may go with somewhat of the same setup but maybe install an on board compressor and wireless switch to make it painless.The day photo was before the lift, night shot was with them. Airlift 5000 is what I use. Air up/deflate next to the rear license place
Did it make a huge difference in the tow feeling for you I see the difference is night and day"pardon the pun"The day photo was before the lift, night shot was with them. Airlift 5000 is what I use. Air up/deflate next to the rear license place
I thought about it. Can always add it I guess.. for now it takes 2 seconds to so at the shop! The onboard would be super nice thoughVery nice! I'm thinking that I may go with somewhat of the same setup but maybe install an on board compressor and wireless switch to make it painless.
Oh yeah for sure. Towing was easy and didnt phase the truck. I just have to remember to lower to about 10psi to get a good softening for daily driving[emoji106][emoji106]Did it make a huge difference in the tow feeling for you I see the difference is night and day"pardon the pun"
