Leveling kit advice
Kylescj5
5.2l
I have a 1999 ram 1500 5spd manual 2wd that id like to level. I don’t know where i can get a leveling kit or what to get. Please help.e1a6094f30ab7753572be742cabebae6.jpg
crazykid1994
Front Lift level or lower rear level?
crazykid1994
Spacers should be fine. Google can be your friend
Ktstull
HEMI 5.7
See if Bilstein 5100 ride height adjustable shocks are available for your truck. I used them on mine and it looks great, plus gave me a little more travel out of my front suspension.
crazykid1994
Wrong truck. These trucks aren’t strut based like the 4th gens.
Ktstull
HEMI 5.7
Ah you’re right! My bad!
318_performance
Kinmundy IL
318 c.i.
I have a 95 ram 1500 2wd an I got the 2” front spacers on mine an I do have enuf clearance to run 33x12.5 without any rubbing. I can try to upload a pic if ya want.
EvilSpirit
5.9 Magnum
People like to use lift blocks or spacers under the coils to raise, or shorter coils to lower vehicles with independent suspensions, but I always advise against the practice. While it's a relatively easy and cheap way to change the ride height, the practice has several things to consider if you are trying to change the height by more than an inch. Here's why I say this.
When the factory designs a suspension, they have the control arm bushings, ball joints, shocks, bumps stops, etc. in the center of their travel at ride height. The control arms are fairly parallel and level to the ground. When you change the ride height by much more than an inch in either direction, several things happen. Many times the vehicle starts hitting the bumpstops, so people trim or remove them, which is not a smart move - they are there to protect the ball joints, shocks, and control arm bushings from damage from overtravel. It is not good practice to run the suspension parts near the limits of their travel at ride height, which is the result of the coil length change - it leaves them much more prone to early failure from wear or pot-hole damage. Also, due to the control arms being different lengths, changing the ride height changes the caster, and it can be hard to get a proper alignment. And one item the forum gurus never seem to consider is something that is always mentioned during PROPER control arm bushing replacement. When bushings are changed, it is very important to have the vehicle at ride height before tightening the control arm fasteners, so they are in a neutral position - failure to do so leaves the bushing elastomers under constant twist and much more likely to tear or wear out rapidly. Yet I have NEVER seen where anybody recommends relaxing the bushings by loosening the control arm fasteners and re-tightening them at ride height after changing the ride height.
This is IMO why changing the ride height (more than an inch) by chopping the springs or putting coil spacers in the 2wd trucks is a bad idea. While it is more expensive, using drop or lift spindles is a much better way of changing ride height, since they don't affect suspension geometry.
