Lifting 6-8 in
Discussion in 'Suspension' started by trucks2887, Aug 13, 2015.
  1. trucks2887
    trucks2887 Junior Member
    30
    Aug 13, 2015
    Ram Year:
    1989 and 2011
    Engine:
    318 and 5.7L hemi
    I have a 1989 W150 4x4 I want to put a lift 6-8 inches on it, with 35-38 in tires. Any insight before I start ordering parts to do this? It has a 2 in lift on it now I just want it higher its going to be a play truck more than anything, but I still want to be able to drive it when I want to joy ride. What would I have to change as far as drive shafts, steering etc. Thanks for info
  2. crazzywolfie
    crazzywolfie Senior Member
    14,102
    2,147
    Apr 6, 2013
    under the truck
    Ram Year:
    81 93
    Engine:
    5.2
    with that much lift you would most likely need something like a crossover steering kit. i think the stock setup may not work with that much lift or would wear out real quick. i think the drive shafts should me ok with that much.
  3. The War Wagon
    The War Wagon Senior Member
    1,617
    1,049
    Jul 2, 2015
    da' 'BURGH
    Ram Year:
    1992
    Engine:
    318 Magnum
    You'll DEFINITELY need custom suspension & steering components. And you can run 35's with as little as 3" of lift.
Share This Page
