light at the end of the tunnel?
Ohninehemisport
Chicago
I also ordered me a set of the no-cut brackets. As far as the thickness, 3/16" is the same gauge as the factory mounts.
He said the no-cut version was designed for a 4" drop. The cut version is more for a max 7" drop, if I remember.
Also check out Inez hotrods on FB. They make a similar set of cut brackets and also drop control arms that allow for perfect alignment.
Ohninehemisport
Chicago
Now All I will need is a set of shock extenders to run stock length shocks. These street performance shocks are on the way stiff side
Quicksilver337
South FL
2016 Ram R/T
Awesome looking!!
what suspension setup do you have?
J3FF3RSON
Louisville, Kentucky
2014 Ram R/T
Saw your truck on that page. Is that really a 5/7 drop? With a drop that low I'd hit every pothole in town. lol
Looks to me like a 3 / 5, whatever it is, it's a great looking truck.
bgray
Canada
Thanks for doing all the leg work guys! Looking forward to seeing the results of the Cut kits. Sure would be nice to get the rear of my truckl to sit a bit lower without that mount being in the way
Ohninehemisport
Chicago
Not my truck. I just borrowed the pics from their FB page. Nice truck though, I believe it's a 4/7 drop. 2" drop arms with 2" drop springs up front. And cut 4" rear springs.
DERJ
Austin
2014 R/T
Guys, I'm so ready to get a set of these... Any details on when / how much the group buy price would be?
I might just order a set now on my own...
Ohninehemisport
Chicago
With these brackets would I still need a adjustable track bar?
The no cut kit also comes with a 4" tracbar relocator. The cut kit comes with a tracbar relocator compatible with up to a 7" drop. You don't "need" an adjustable track bar but if you wish to fine tune the left/right axle position then you can get one.
Bigfoots03hd
New Port Richey,Florida
I'm only doing a 4 inch drop in the rear so I'll be getting the no cut kit
Txhemirt
Lubbock, Tx
Do you know about how long the install should take for the no cut style ?
razor1
razor1
St.Petersburg Fl
hopefully no longer than servicing the Spohn arms, about 2 hours.
Ohninehemisport
Chicago
If you already have a drop kit that includes a tracbar relocator you won't need the one included in this bracket kit, so -$50 from $450 for the no-cut kit. And an adjustable tracbar is not really needed.
