Limited Air suspension and WD hitch?
karjar
For those that have factory air suspension, and use a WD hitch, what is your process? hook up, apply weight distribution system then start truck and let it level last little bit with the auto levelling of the system??
As a second question, if you have air suspension and live in cold winter climates do you have problems with the factory air system?
twolabsdad
Diesel
You have a Tow/Haul button below the radio. Turn it on, I think that will cover you. You should turn it on whenever you're towing or hauling.
