Limited steering wheel crack
Discussion in 'Interior' started by DeereGuy, Jan 11, 2017.
  1. DeereGuy
    DeereGuy Preferred Vendor
    488
    338
    Nov 9, 2016
    Pittsburgh, PA
    Ram Year:
    Engine:
    I picked up this beauty off of eBay for a really good price. I knew it had a small crack in it but I was hoping it wasn't that noticeable. Unfortunately it's pretty noticeable. Anyone have suggestions on how to fix it or conceal it a bit? the seller claimed it was brand new just a little bruise but I'm not sure I want to put it in my truck the way it is now. Thanks!!
    [​IMG]
    [​IMG]
  2. quietpeen
    quietpeen Administrator Staff Member
    21,983
    1,870
    Jul 14, 2010
    Ram Year:
    2016 1500 Sport Crew Cab 4x4
    Engine:
    Is that on the back side? I don't see it in the first pic
  3. quietpeen
    21,983
    1,870
    Jul 14, 2010
    Ram Year:
    Engine:
    Also off topic question. Is that part of the steering wheel heated?
  4. 00R/T
    00R/T Supporting Member
    1,451
    899
    Apr 18, 2016
    CT
    Ram Year:
    Engine:
    You're right. It's not fixable and you definitely don't want it in your truck. I'll take it and dispose of it properly for you.
    Is that a crack or a scratch? It looks like it might be a scratch in the finish. That's going to determine what you can do with it.
  5. DeereGuy
    488
    338
    Nov 9, 2016
    Pittsburgh, PA
    Ram Year:
    Engine:
    It's towards the front side of the steering wheel right over the curve that is why you can't see it from the front.
  6. quietpeen
    21,983
    1,870
    Jul 14, 2010
    Ram Year:
    Engine:
    I don't know, if it's just a scratch and not a crack I would see if I could just make it less noticeable
  7. DeereGuy
    488
    338
    Nov 9, 2016
    Pittsburgh, PA
    Ram Year:
    Engine:
    It's actually a crack. There is a small indentation at the same location. I bet it was dropped. I'm actually not sure I really like the feel of the top section...
  8. DeereGuy
    488
    338
    Nov 9, 2016
    Pittsburgh, PA
    Ram Year:
    Engine:
    I really don't know. I assume it is.
  9. mcaligiuri
    mcaligiuri Member
    31
    99
    31
    Aug 24, 2016
    Ram Year:
    2016 ram 1500 express crew cab
    Engine:
    Can you try wet sanding and polishing it? I would try it got nothing to lose
    DeereGuy likes this.
  10. 00R/T
    1,451
    899
    Apr 18, 2016
    CT
    Ram Year:
    Engine:
    If it's cracked, your only real option is probably to fill it and then smooth it out. I've repaired wood steering wheels in the past but most have just required sanding out the scratches. CA (super glue) works well for filling in deep scratches, so you might be able to use that.
Share This Page
