Linkage??
Pat Pitts
Hello, I have a 2001 dodge ram 1500 two wheel drive. My gear indicator on the dash lines up perfect in P, R, & N. To put it in drive I have to put it on D and then slide it to the left just a bit or it will be in second. The same goes for 2 & 1. I am guessing this would be the linkage in the transmission seeing that P, R & N work fine. Is this a hard thing to fix, thinking of doing it myself.
Thanks,
Pat
Supershockers
5.9 magnum
Watching - as I have about same but net is rev, between net & drive is net, drive is 2, 2 is 1 and 1 well you can't see it. lol bugs the **** out of me
Shadow_Death
Killeen, Tx
If you have the factory service manual there are instructions in there on how to adjust the shift linkage. It's fairly easy actually. If not I can take some pictures after work today but that will be around 5pm before they get posted.
Factory service manual for your 2001 Dodge Ram: https://drive.google.com/file/d/0BwDkuRJfDNZEaVhqcm93M0lEM1E/view
You should also have the option to download it from that site.
You should be looking for page 21 - 251 to 21 - 252.
