MoparSickness77
- Jul 29, 2011
- 104
- 2
- 2007
- 0
Took my truck into to have what I thought was a leaking oil pan but it turned out to be timing cover gasket and seal. Then they made a list of other things wrong:
-harmonic balancer- oil soaked, worn and deteriorating damper
-drive belt tensioner assembly, slight play, will require belt
-water pump- slight play, will be required w/ timing cover gasket, recommend thermostat and gasket
-steering rack n pinion- leak
-LF upper ball joint play, recommend all
-power steering pressure line- leak
-oil pressure switch- required w/ timing cover gasket
-lower control arm bushings- worn
-steering shaft- rusting recommend R/R, clean n grease
-transfer case service- tail shaft seal leak
-slip yolk, seal and bushing worn and leaking
-transmission mount- cracking
-leaf spring bushing- worn
-LF and RF motor mounts- cracking
-radiator- slight leak at RF tank, recommend w/ timing cover gasket
-trans quick connects @ cooler- small leak
Holy crap thats alot!
Anyone done any of those things or any input? Ill be looking into doing what I can myself.
