Long haul Towing preparation
Discussion in 'Towing & Hauling' started by Hardcore1, Nov 13, 2016.
  1. Hardcore1
    Hardcore1 Member
    43
    Oct 23, 2016
    Ram Year:
    Engine:
    One of the first drives of my new to me 78K mile 07 1500 will be a long run towing a 7800lb load from NJ to the Florida keys. Is there anything I should be doing to prepare the truck for this haul? I am thinking to drain and fill the transmission maybe 3 times in succession since the trucks service history is unknown. Anything else you would do to prepare?
    usaf2006 likes this.
  2. Bullitt5339
    Bullitt5339 Senior Member
    920
    507
    Jul 5, 2015
    St Pauls, NC
    Ram Year:
    Engine:
    3.7
    I'd just do normal maintenance plus inflate the tires to their max rated pressure before leaving.
    1bad15RAM likes this.
  3. usaf2006
    usaf2006 Senior Member
    3,853
    1,036
    Mar 28, 2014
    Augusta, GA
    Ram Year:
    Engine:
    Do you have the tow package? You could upgrade to a ram 3500 trans cooler to help, I see lots of guys who tow a lot do it. If I towed I probably would.
    Make sure your spare tire has air in it just in case! Also wouldn't hurt to take it down from under the bed (if you haven't) to make sure you can lol.
  4. Hardcore1
    Hardcore1 Member
    43
    Oct 23, 2016
    Ram Year:
    Engine:
    Good Suggestions! I was thinking to add a trans temp gauge. Are there any write ups or suggestions of how to add a trans temp gauge and which one are best?
  5. Hardcore1
    Hardcore1 Member
    43
    Oct 23, 2016
    Ram Year:
    Engine:
    Also thinking about changing the internal filters both pan and spin on when I change the fluid. Might change the pan to one with a drain plug too while I am at it for easier future fluid changes.
    Anyone here doing stuff like this? Any brands to use or stay away from?
  6. justin13703
    justin13703 Senior Member
    28
    1,006
    296
    Oct 15, 2014
    MD
    Ram Year:
    2008
    Engine:
    If you're changing the fluid then definitely change the filters too. Oem ones will be the best.
  7. usaf2006
    3,853
    1,036
    Mar 28, 2014
    Augusta, GA
    Ram Year:
    Engine:
    Yeah use oem, I've heard too many issues with other filters not having the right flow rate, etc., causing issues.
  8. Bullitt5339
    920
    507
    Jul 5, 2015
    St Pauls, NC
    Ram Year:
    Engine:
    3.7
    Most Mopar oil filters are made by Purolator now, so you might as well just buy the Purolator and save some money. Wix filters are also high quality and are used by many other car companies as their OEM filters, so I don't shy away from them either.
  9. usaf2006
    3,853
    1,036
    Mar 28, 2014
    Augusta, GA
    Ram Year:
    Engine:
    Good to keep in mind. I want to do my trans in the next year or so..
  10. Mega-Hemi
    Mega-Hemi Senior Member
    1,138
    219
    Jun 28, 2010
    Back in New York!
    Ram Year:
    Engine:
    Cummins 6.7
    I may know someone with a 24 row cooler for sale.
    Also have a Superchips Flashpaq 3840.
Share This Page
