I have a '12 with the Cummins. The stock milage is horrible from what I can remember. 18 highway (if babied), 13 around town & 8-9 pulling the camper. Truck got deleted at about 5,000 miles and has 63k on it now. 22 highway, 17 around town & 12 pulling the camper. Rule of thumb is 3-4 mpg gain from doing deletes on a non-DEF truck (Ram started using DEF fluid as part of the emissions system in '13).
Regardless of the year, common issues from emissions equipped trucks are all emissions related. Soot clogged turbo, failed EGR valve or cracked EGR cooler, soot clogged grid heater are fairly common on trucks with a lot of idling hours. If you plan on keeping it stock I highly recommend getting some sort of bumper to bumper warranty for the first year or so to cover anything that pops up.
Not trying to deter you from buying, it's just guys join igotacummins all the time looking for help with issues after buying a used truck. There are plenty of good ones out there but it seems good to be prepared for the worst, just in case.
Also, when looking used, you will see a the '12s prices higher than 13s & 14s. The reason is the pre '13 trucks are much easier they are to modify. CANBUS is much less finicky, tuning is cheaper and requires less hard parts to remove. Occasionally I think about trading in my Cummins on a newer 6.4 since I don't tow that often but I am so happy with how she's running I can't imagine giving her up now
Sent from my LG-V510 using Tapatalk
