Low fuel pressure issue
schroederMP
Indiana
Cummins
So I've noticed that since the temps have gotten cold around here (10-20 degrees with negative wind chills) my fuel pressure has went WAY down.
Normal cruising I'll see 16-17 psi and as low as 14 psi at WOT.
Now that its cold its been cruising at 13-14psi and 12 at WOT.
Is the cold temps the cause of this? Or am I just having MORE problems with my AirDog lift pump?
My rail pressure hasn't changed any...if that helps
3quarterTon
I would think the fuel viscosity is thicker. I've heard of truck in those temps with fuel gelling. Just an idea.
3quarterTon
I would think the fuel viscosity is thicker. I've heard of truck in those temps with fuel gelling. Just an idea. If rp remains the same I wouldn't worry.
schroederMP
schroederMP
Indiana
Cummins
Makes sence, I figured the anti jelling stuff I'm using would prevent that in these temps.
I may try and insulate my filters
