Lowered Suspension: An Engineering Perspective.
Discussion in 'Lowered' started by Dubstep Shep, Dec 19, 2016.
  1. Dubstep Shep
    Dubstep Shep Senior Member
    2,235
    491
    Aug 4, 2014
    Houston
    Ram Year:
    2014 R/T
    Engine:
    That's more or less where I'm at now. One full coil off the front and three off the rear. The rear still sits too high, so I ordered a set of Belltech 4" rear coils. I'll try those and see how they are.
    I'm also going to compare the Crown 1/2 springs to these.
    moregrip likes this.
  2. PassivAggressor
    PassivAggressor Senior Member
    1,407
    494
    May 24, 2014
    Ram Year:
    Engine:
    Sweet. I may cut half a coil on the front and the three on the back. I need 20's!
    Sent from my VS990 using Tapatalk
  3. Dubstep Shep
    2,235
    491
    Aug 4, 2014
    Houston
    Ram Year:
    2014 R/T
    Engine:
    What're you running on now?
  4. PassivAggressor
    1,407
    494
    May 24, 2014
    Ram Year:
    Engine:
    Stock R/T suspension.
  5. Dubstep Shep
    2,235
    491
    Aug 4, 2014
    Houston
    Ram Year:
    2014 R/T
    Engine:
    Well that's what I had before I cut them, so yours should sit pretty close to mine.
    PassivAggressor likes this.
  6. PassivAggressor
    1,407
    494
    May 24, 2014
    Ram Year:
    Engine:
    Cool. I don't want mine that low in the front though. So I may just cut half a coil in front. It still seems like you have an inch to inch and a half of rake in the pics. You're running the B/T drop bracket or just the adjustable track bar?
  7. Dubstep Shep
    2,235
    491
    Aug 4, 2014
    Houston
    Ram Year:
    2014 R/T
    Engine:
    Yea, start with half a coil and see what you think. You can always cut off more or add a shim.
    And yea, it's still a good inch or two of rake.
    No bracket, and I haven't adjusted the bar yet. It actually just sits about right on its own.
  8. Dubstep Shep
    2,235
    491
    Aug 4, 2014
    Houston
    Ram Year:
    2014 R/T
    Engine:
    Here's how mine sat stock:
    [​IMG]
    Here's how it sits now:
    [​IMG]
    [​IMG]
    Wild one likes this.
  9. FlynDutchman
    FlynDutchman Senior Member
    102
    30
    Apr 9, 2016
    Menifee, CA
    Ram Year:
    Engine:
    If you still have issues with the truck not sitting close to level on the left and right side. Loosen all the bolts on the rear upper and lower arms and the pan hard bar. Drive the vehicle slowly in your neighborhood and than on level ground retighten (torque to factory spec) the upper arms, lower arms and pan hard bar with the wheels on the ground. Recheck your measurements and hopefully this helps.
    DERJ and Wild one like this.
  10. Dubstep Shep
    2,235
    491
    Aug 4, 2014
    Houston
    Ram Year:
    2014 R/T
    Engine:
    Yea I made sure not to tighten down the control arms until the suspension was settled. That's not the issue, it's just that the drivers side is a lot heavier on these trucks thanks to the fuel tank.
    For those that don't understand why this needs to be done, it's because factory rubber bushings are preloaded to a set ride height. Rubber bushings twist as the control arms move up and down, and as such they act like a spring. That's why you can't just turn a rubber bushing control arm as it sits. With poly, delrin, or metal, the joint slides rather than twists.
Share This Page
