M² Mods Intro & Project List
Twan Nguyen
Washington
EcoDiesel 3.0
I need to purchase the fog light harness extension for 2014 ram 1500 slt. Thanks!
Sent from my SM-G965U using Tapatalk
Mpgrimm2
Mpgrimm2
Preferred Vendor
SC
2022 Ram 1500 (5th Gen)
5.7L
Mpgrimm2
Mpgrimm2
Preferred Vendor
SC
5.7L
Specialk
Chicago
Ecodiesel
Hi,
I'd like to get a 7 spd harness and 911 bypass plug please.
Thanks!
R.L.K.
Bristol , Tn.
Hi,
Thanks!
You have come to the right place Sir , I'm sure Mpgrimm2 will answer you soon !
M2mods is just unbeatable imo [emoji1303][emoji1303]
Mpgrimm2
Mpgrimm2
Preferred Vendor
SC
5.7L
g-ram
US
HEMI 5.7
Where can I get the media hub conversion harness to buy
Sent from my SM-N950U using Tapatalk
bmhenry
Lincoln county, Missouri
Hey guys, finally made it back to the dealer today and they got the correct codes put in so now I have the Cargo Camera icon on my display but I still need that cable... How much would you charge to make me one and how long will it take?
This is for a cable to go from the factory Mopar Cargo Camera in the LED version of the CHMSL to the factory 8.4 screen on a 2018 Ram 2500HD Laramie Cummins Diesel with the Crew Cab.
I am also interested in the harness. Is it available?
Pacheco172
2013 RAM 1500 4x4
Hi M2 mods! I need the Extended 4 or 7 Speed Conv. Harness w/ATC Temp Sensor Wiring/Plug $160
Austen
Missouri
Alright I have a 2017 Ram 2500 6.7 Tradesman I have added the 8.4 RA4 with Customtronix Enigma Premium kit which adds the button for the oem cargo camera into the radio. I would greatly appreciate a harness that has a way to plug and play the OEM cargo camera into the RCA plug the Customtronix kit has added for the cargo camera. I believe it will get power from the factory connector that plugs into my oem non cargo camera third brake light. So if I'm not mistaken all I need is a long cable with the correct connector to plug unti the extra plug on the oem cargo camera 3rd brake light with a rca cable on the radio side
DeereGuy
Preferred Vendor
Pittsburgh, PA
I could build you a cargo cam harness to replace the missing factory wiring but it would not terminate with an rca plug. It would have the three factory pins on the radio end that would plug into the radio c1 connector.
STecoD
NorCal
2015 Crew Cab Tradesman
3.0L Diesel
I have installed the new harness for the humidity sensor. Works great just like RickRams truck. ce29c5c727da61a409e5151f72fd48bc.jpg
To drop the headliner enough to get to the wiring you have to pull both “A” pillars, passenger side “B” pillar, and remove the visors. c0c0bdcd96f3c5c4315c88c5f4631a57.jpg
The “B” pillar you have to pull the bottom section first, remove the cap over the seat belt bolt and remove the seat belt bolt. Then two bolts under the covers on the grab handles. Always nice to have someone there to take pictures and make fun of you while you are working on it. Thanks Rick and both Mikes for all of your help.
Austen
Missouri
How much would you charge for the harness?
circuitguy
Elk Grove, CA
2017 Ram Tradesman Regular Cab
5.7L HEMI
Trying to PM but its not working for me, keeps saying I am Spam so I will post this here.
Good evening everyone,
Found the post about the following:
Base to 8.4 Radio Fan Conversion Harness (7 speed Fan specific models)
Fog light extension harness
I have already installed the mopar fog lights and the mopar harness that goes from the lights to in the engine bay.
I have a 2017 Ram Tradesman that I want to upgrade the Fan / AC switches and also install add the fog light package. Please let me know whats needed and a price for all.
Read lots of good thing about you guys and all the help you give to the Ram owners, hopefully you can help me out too.
C
Mpgrimm2
Mpgrimm2
Preferred Vendor
SC
5.7L
Pm sent with my contact info
Edit: if that doesn't work for you just add @ msn.com to my user name for my email.
M² Mods.
Canadian-Hemi
Ontario, Canada
2016 Shorty (RCSB)
5.7 L
Hi I'm new to the forums and I can see exactly what I need, but I can't figure out how to send a PM to Mpgrimm2 about acquiring a 7 Speed Conversion Harness to finish my project off.
