Max Built up Payload '13-18 1500 4x4??
RamShark1
Los Angeles
Guys, who knows what could be the max in bed payload that could be built up in a '13-18 Ram 1500 4x4? Needing a newer truck. Was darn sure I needed a 2500 to use a pop up truck camper, DRZ400E in tow hitch rack, along with supplies and occupants, usually 2, but want to double check on what a newer coil link rear 1500 could be built to handle, safely, especially with stronger rear bags swapped into the Ram Air suspension option. Any qualified opinions on this?
Thanks.
UnsatFC
Active duty NAVY
New Jersey
What pop up truck camper you looking to use? The weight of the bike alone is a little over 300. Leaving your with around 1,300 ish for everything else.
mtofell
Keep being sure :)
A 300# bike hanging off the hitch AND a camper in the bed?? That's going to be pretty tough to pull off with a 1/2 ton. Especially, a Ram that has the lowest ratings of the half tons. My buddy has a 1500 with air suspension and his payload rating is 1070#.
GsRAM
2017 Dodge Ram 2500
Hemi, 6.4L
Keep being sure :)
Agreed, your in 3/4 ton truck territory with what you want to do.
maxx442
2022 Ram 3500
6.7 H.O.
You can add new springs, airbags, sway bars, etc. It still won't raise your payload rating because you still have a half ton frame and axles. By the time you spend the money to do all of those things you will have the cost of a 2500 invested into it.
HvyDuty
Perrysburg, OH
5.7L
