HamiltonSeth
- Feb 15, 2011
- 1
- 0
- 2004
- 5.7
Hello Everyone,
Does a Mcgaughy's 2/4 flip kit require shims to correct the pinion angle?
I had thought that the kit moved the rear axel back so that shims would not be needed. Is that correct?
I know there are a few threads out there on this but I just couldn't seem to get my question answered.
I have a 2004 RCSB that I installed the kit on. I do hear a bit of noise from the rear, but it is only when I leave the driveway in the morning. Once I have driven for about 20 seconds it is gone.
Also, I am going to weld the perches sitting on the axel. Should I also weld the new mount that sits inbetween the axel and the leaf springs? This is the C shaped piece, I figure welding it to the stock perch and the axel could only add strength. Your thoughts?
Thanks for your help.
