Mega cab difference?!?!
Ratket
Arizona-
So I know supposedly the 6.4 Hemi mega cabs are rated at a slightly lower hp/ tq and we don't have the center shock from the axle to the frame out back. Sooo I really have never found a definitive answer on this. I know guys say they can smoke the tires on their 2500 crew cabs, Sadly I can not. So is it just tuning? I mean that's all that could be different right?? But why? any one have any answers? Thanks fellas.
Ionicbrick
Where does it say they are rated for less hp and torque? I can break the tires on mine easy... But you do have to turn of the traction control... These crappy FS tires probably play into that a bit...lol
hemi1282
Arkansas
2016 Ram Tradesman
U can't smoke your tires? Ya should be able to I can, I seen where somebody posted the shock is for wheel hop and the mega cabs don't need it, dunno how true that is but every mega cab I've seen with a 6.4 none have them I've checked most of'em around here but ya with factory rims tires mine lights them up
Ratket
Ratket
Arizona-
What elevation do you guys live at? and I swear I saw in the brochure the mega can had less hp/ tq - I think it was the way they dyno it.
Ionicbrick
I'm at 5400 near Denver. I've not seen such a brochure or dyno numbers... You don't happen to have a pic or link to either do you?
hemi1282
Arkansas
2016 Ram Tradesman
South Arkansas here, elevation like 250 I think that detune only applys to the 3500 mega cab
Ionicbrick
I thought that was for chassis cabs only. That is a commercial brochure on the link... Maybe it's just confusing? I still haven't seen any dyno work for any of the 6.4's... Anyone know of any?
EvanYJ350
2016 2500 CC Air Susp
6.4L 392 c.i.
I read somewhere that it was a weight class issue, and that they measure it differently at a different RPM. Same engine, same power, just measured differently.....
SouthTexan
408 CTD
The 6.4L and Cummins in the chassis cabs are rated lower because they have a different emissions certification they have to go through than the pickup versions. They have to go through a different certification because Ram does know what body the end user will put on the truck so it cannot do the same emissions certification as the pickups with beds. They run the chassis cabs through what is called an engine only certification which is more stringent than the pickup one.
Skrap
Orange County, CA
2015 Laramie MegaCab 4x4
So, I assume the MC are not detuned? Only the Cab and Chassis models are?
Ratket
Ratket
Arizona-
I don't think any of them are de tuned.. just the hp/tq ratings are different because they are measured differently. But in reality they are the same?
NewBlackDak
Hemi 6.4L
None of them are detuned. It has to do with noise levels, and they can only measure the HP/torque at max decibels.
SouthTexan
408 CTD
No, the MC should not be tuned differently and it should only be the cab and chassis models. They use the same SAE standard for both numbers, but the engines are tuned to meet the emissions certifications. Many people believe they are tuned for reliability of the heavier duty cycle, but this just isn't the case. It has to do with emissions just as the representative from Ram states in the video below.
https://youtu.be/TNRwwUIsG4Q?t=3m43s
