Hey guys this is my first time posting here but i have learned a ton from other posts. So here us my issue.
My truck overheated a few days ago but was not left hot for long. I let it cool down put water in it and got it home ( couple blocks away) but was running realy rough. found a leak in the radiator so i replaced it. A code was on for 02 sensor. Replaced it. no more code. Fan relay code came up. Fuse 39 replaced it. Code gone. Still running rough code 0206 came up injector 6 and code o352 coil 2. Replaced the injector and coil. Codes gone. Then Code o351 comes up. Coil 1. Replaced it. Code gone. But codes 0352 and 0206 come back......im stumped and thinking pcm. Any ideas or input would be great with out taking it to a garage or buying a bunch of tools and scanners because i realy cant afford either.
