GraniteCrystal
So after many months of deliberation and planning finally installed my OEM backup camera. BUT, I didn't follow the directions in the kit.
What I did was I used the wire in the kit to make my own custom harnesses that mirror jeepguy's harnesses.
So for those who would like to do the same, here are few things that make this install a lot easier.
1. All the pins needed (kit already contains pins for connector at tailgate and radio) can found in any year DODGE CALIBER.
a.) The connector located underneath driver side door on TRUCK can be found on engine harness of CALIBER behind driver side headlight.
b.) The pins needed for white connector under dash on TRUCK are the same pins as the POWER MIRROR SWITCH connector on CALIBER [forward most connector on drivers side window switch bank]
NOTE: CONNECTOR IS NOT THE SAME, BUT PINS INSIDE BOTH ARE THE SAME
To do the install, make the harnesses and install following jeepguy's instructions.
I hope this helps some people who wanted a jeepguy harness, but weren't able to get one.
