more cam talk
truckin151
2013 sport
You guys are really fine tuning here when comparing QC and RC models. Looking at the two the QC are what 600 pounds heavier and something like 30" longer. The longer wheel base probably makes the biggest difference. Same basic engine mods, trans and gear ratio should give very similar results with the RC having only a slight advantage. Maybe a RC with 3000 stall, 4:56 with a XFI 273 would make a good combo. The XFI still has 114 LSA. Anyone have thoughts about tuning with the SMT6 or something other than SCT or DSP?
Talk to Danniel (Kay9) he put a 273 in his rc. Its to much of a high end cam, he put in 4.88's and that wasn't enough, he also wants to put in a 3400-3600 stall. That cam is almost all top end. The 268 is more of a mid/mid-hi cam, so you still get a nice strong mid range.
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
I hadn't heard anything from Daniel about how his install went. But thought he was on track building a very serious street/strip truck. I figured the 4:88's would handle any of the cams and the high stall TC would be icing on the cake. Just couldn't see how he was going to hook it up without tubs and fat tires.
truckin151
2013 sport
From what I have heard (even with his 456's and 2800 stall in) it was a dog off the line until it picked up, it is a top end cam. Its an aggressive cam but its a top end cam that (I believe) makes most of its power/tq above 6k rpms. I dont think he's taken it to the track yet, haven't heard much since he lost his drive shaft on the highway. I'd ask him to post up here but some ********* made a few comments about his truck so he quit this site.
Redtruck-VA
Virginia
How did I miss that? I like what he has done with his truck. Daniel actually does modification most guys are just flapping their gums about. **** them, this ****** me off.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Someone on DT posted the powerbands on the 260 268 and 273 and the 268 is the best of both worlds according to the dyno numbers.
Yeah, I know that guy. Posted this.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
^^^Haha teach was it you? sorry brain is still waking up at work. If the truck was a track only truck with a stroker then the 273 is the ticket a street truck a comp 268 with 2800-3k stall would be golden.
I found that chart on some site a while back when I was comparing cams. It is good info bc it shows exactly where each cam is making power.
chefred112
Tracy, CA
2005 QC 2wd
392 Hemi
Pare, after i saw this i wanted to research exactly what Daniel was doing on his truck and realized that he takes his truck to Chris (at mike's place) to get the work done meaning most of the work is done by Chris. And after more research i realized I have had a few conversations with Chris regarding his build (small world). I think the build is still ongoing but he needs to take it to a track and run it so we can look at the timeslip and determine where any improvement needs to be done..
truckin151
2013 sport
Yep, Im hoping it will be, I got a 2800 stall and the 4.56's so that should put me right where I want to be for that cam.
See Red - the 273 puts out the most power but take a look where trhat power is being made. To get it to its sweet spot you really need more lowend. The 268 has it beat up to about 6k rpms and then it hits where the 273 starts hitting its sweet spot and building more power.
I know I was pissed about it too, we've had nice long talks about what direction we are going with our trucks, and his truck is absolutely sweet in person (helped for a little while while they were putting the 273 in). But a couple guys didn't think about there comments and bashed his ride in the process so he took off.
truckin151
2013 sport
Yeah we were over there for a while when chris was doing the cam install and UD, I couldn't stay the whole day though so I never got to hear it fire up.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
You will need dsp to max out the rev limiter or else the stock rev limiter will stop it soon as the 273 gets goin.
Redtruck-VA
Virginia
Everyone is looking for the magical combination, that's why there are so many cams and add-on available. And the way i see it if some choose a different way to get what they are looking for it is not our place to knock them or their rides. Hell i got a shed full of engine parts I have run over the years that didn't quite work out the way I had planned. So what, it's being out there doing something that makes it interesting and if there is an occassion we can get it right then that's the reward. The combo Daniel is working on is not his first and probably won't be his last, but I wish him the best. rant over...
truckin151
2013 sport
His truck will be nice once he gets all the kinks worked out.just sucks that he left cause of some ******* comments.
chefred112
Tracy, CA
2005 QC 2wd
392 Hemi
...my combo is magic... it was a long journey but i have nothing left to do but stroke it now (not really in my plans but I said the same thing about spray), not many qc's faster then me (can count them on 1 hand)... I have over 191k miles on my 05 which shows how much I love driving it on the street, for a qc i feel a spartan is the best cam for it as well (I wouldn't suggest it for rc's). The 1st drive after my cam install put a BIG smile on my face (that's what mods should do) and made it bigger after the custom tuning..
Redtruck-VA
Virginia
Ken,
DSP can't adjust rev limiter or the speed restricter. I believe that is why folks stack SC with other tuners.
truckin151
2013 sport
Only on the 03s, it can and does/for everyone else
chefred112
Tracy, CA
2005 QC 2wd
392 Hemi
I was thinkin same thing..my dsp is set for 200mph and 7k wot shifts...a bummer with 03's
truckin151
2013 sport
Mine is raised to 190mph and 6300rpm. The 03s got screwed for tuning
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Like said above it can in just bout everything besides for an 03...
