motor sometimes dies when coming to a stop
jerryt
crossville tn 38572
My 04 1500 with the 5.7 hemi will some times die as I am coming to a stop. I can start it back up and it seems fine for a while. I cleaned the throttle body, but it still does the same thing. How do I fix this?
Thanks, Jerry
cliftonclendenen
York, Pennsylvania
4.7L V8
Thanks, Jerry
I had this happen to me once going down my driveway. 06 4.7 4x4. Seems to be a one time only deal for me. How many times has this happened to you?
dexter
Banned
It can be a few things:
Try Gumout Regane fuel system cleaner
Problem with ignition, plugs etc
Does your truck have a mass air flow sensor, Throttle Position Sensors?
need new air filter?
J
jerryt
crossville tn 38572
Air filter is good. PO gave me a set of spark plugs with the truck. He thinks the ones in the truck have about 90k on them. My son is going to install them in 2 weeks. I could do it but since he volunteered I'll let him do it. At 75 years old I'm not as limber as I used to be. I'll give it a drink of fuel system cleaner too.
Thanks
Luis tucker
Woodland
It may be the fuel pump giving you a warning it's about to give out on you .my Mopar unit just up an died on me so I replaced it with a cheaper eBay one that was half the cost but only had a year warranty here I am a year later had misfire codes an stalling, hard start even when warm replaced everything in the spark and air area just to find out it was the check valve giving out on my crummy eBay fuel pump still functions but after adding an inline check valve one way i haven't had the problem since haven't stalled an no more misfire !
atom13
USA
Na
Na
Not sure if the 5.7 have a pcv or egr valve. Motor cannot idle if they are clogged. If it stays running with throttle input then most likely it's clogged. I would start here and move down the list. This is the cheapest fix.
