My 04 Ram 1500 Mod thread
HeavyD
HeavyD
Medicine Hat, Alberta - Canada
4.7 SOHC 5 SP Auto
Hm not my style, but everyone's style is different. I think to me it's just looks bland because there's nothing from front front of hood to the back, of that makes sense.
Ya, I thought the same, its just out of place, I was trying to make it look like the ram head emblem, but didn't work out right.
EWC88
Southern NJ
Yea making it look like ram head is awesome, but when it's on truck it's not as great as I was hoping. But like I said everyone's style is different, but your right it looks a little out of place.
HeavyD
HeavyD
4.7 SOHC 5 SP Auto
Also did seafoam in the vacuum line - did smoke much not like on youtube.
Put a WAI on & small antenna.
HeavyD
HeavyD
4.7 SOHC 5 SP Auto
my post earlier today disappeared so here it is
Changed Spark plugs today, all between 0.060 - 0.070 & can see wear without measuring gap.
Took less than 1 hour, not one plug was hard to get out.
Also don't know if its a problem but the rear pass side plug was wet & I mean oily (worse than the pics) but not on the treads, where the coil connects at the bottom.
HeavyD
HeavyD
4.7 SOHC 5 SP Auto
cleaned throttle body, buffed out most of scratches on hood, cleaned windows(inside), put black paint on major scratches & paint chips, added more chrome molding & tailgate emblem.
EWC88
Southern NJ
Good looks good! Clean throttle body A+, I need to do it as I said it other thread lol. After cleaning it I heard we have to reset the PCM or something, is that correct?
HeavyD
HeavyD
4.7 SOHC 5 SP Auto
I don't know, I didn't.
made my truck look uglier - kind of
HeavyD
HeavyD
4.7 SOHC 5 SP Auto
Also since my list of stuff to do is coming down.
1 - still need to replace power steering hoses (returns) - have them just have to install.
2 - ball joints - ordered lower with lowering springs (1 1/2")
Not Ordered
3 - upper ball joints
4 - sway bar bushings
5 - front engine seal (doesn't leak that bad)
then cosmetic
6 - front & rear bumpers
EWC88
Southern NJ
Yea I would put that piece back on lol, unless your just waiting for new bumper then your good.
EWC88
Southern NJ
Oh ok, smart then, I thought you took it off to see if you like that look better lol.
HeavyD
HeavyD
4.7 SOHC 5 SP Auto
Got my lower ball joints & 2" lowering springs with 1/2" lift blocks.
Also installed hood scoop today -
HeavyD
HeavyD
4.7 SOHC 5 SP Auto
here are pics of bumper pull - hole was in wrong spot - thinking of drilling a hole & pull again.
pics of all season tires I bought for the truck - will put on after wheel alignment
& pics of how messy my mini garage is.
EWC88
Southern NJ
Yea try drilling hole in other spot and try, all else fails then save to buy new or used. Truck looks nice and clean!
HeavyD
HeavyD
4.7 SOHC 5 SP Auto
Ya no matter how I do with pulling the dent, I will get a new one some time.
just putting money into the underneath right now.
HeavyD
HeavyD
4.7 SOHC 5 SP Auto
got my shackles In & installed today.
So far its only 1 1/4" actual drop & I did go for a drive to get the leafs to set.
