My 2nd Truck A 2004 Quad Cab.
Discussion in 'General Discussions' started by JimsRamTruck2012, Sep 28, 2015.
  1. JimsRamTruck2012
    JimsRamTruck2012 Senior Member
    5,711
    1,574
    Jun 27, 2013
    Central, NJ
    Ram Year:
    Engine:
    On September 11, 2015, I purchased a 2004 Quad Cab.
    So far I've replace the following parts because they were broken - the overhead console, cup holder, antenna, and rear view mirror.
    I also, installed a new tri-folding cover for dry storage.
    Here are some photos of the truck:
    [​IMG]
    [​IMG]
    [​IMG]
    My plan is to make some money moving small loads for people and to take my g/f and her son where ever we want to go in comfort.
    The truck only had just over 80k on the clock and the only issue so far has been replacing the O2 sensors under warranty.
  2. ST-8
    ST-8 Senior Member
    1,953
    584
    Mar 26, 2013
    Ram Year:
    Engine:
    Looks like a damn solid truck
  3. RonJon '06
    RonJon '06 Senior Member
    3,289
    1,041
    Jan 2, 2014
    Southern Minnesota
    Ram Year:
    2006, 1985
    Engine:
    5.7, 360
    Looks good. :waytogo:
  4. JimsRamTruck2012
    5,711
    1,574
    Jun 27, 2013
    Central, NJ
    Ram Year:
    Engine:
    Thanks guys so far it is. :waytogo:
  5. codered
    codered Senior Member
    19
    9,493
    2,117
    Aug 18, 2014
    in da ghetto, FL
    Ram Year:
    1998 QCSB
    Engine:
    magnum 5.9/360
    damn it's pretty congrats man. :cheers:
    JimsRamTruck2012 likes this.
  6. Darrell85
    Darrell85 Member
    32
    Jul 31, 2015
    Ram Year:
    Engine:
    are you going to install a fifth wheel
    or lift it at all
  7. JimsRamTruck2012
    5,711
    1,574
    Jun 27, 2013
    Central, NJ
    Ram Year:
    Engine:
    No install of 5th wheel. If I was going to do something like that I would have gotten a 3500 which can handle pulling a whole lot.
    Also, no lift on this one. Setting up to be more of a simple work/ rec truck than anything else. :)
  8. SilverStreak88
    SilverStreak88 Senior Member
    3,951
    1,583
    Jul 20, 2015
    Houston, Texas
    Ram Year:
    Engine:
    5.7 Eco Gasser
    Nice truck, 2 or 4wd?
  9. JimsRamTruck2012
    5,711
    1,574
    Jun 27, 2013
    Central, NJ
    Ram Year:
    Engine:
    4wd. Where I live you need it.
    Only thing I have to locate is the fuse for the window and door switches. It's not marked on the fuse cover and I can only open and close the windows with the driver's door and window switches.
  10. xtremewlr
    xtremewlr Senior Member
    398
    87
    Feb 12, 2015
    Lemon Grove, CA
    Ram Year:
    Engine:
    Common issue with the Ram. If you are only able to control the windows with the driver side switch, try removing it, cleaning the contacts and using some dielectric grease when you reassemble. If that doesn't work, then you might just have to replace the driver side switch assembly.
Share This Page
