Need help! Remote start
Discussion in 'Audio & Electronics' started by Mikeyn23, Dec 26, 2016.
  1. Mikeyn23
    Mikeyn23 Member
    25
    52
    Sep 18, 2016
    Ram Year:
    2003
    Engine:
    So I got a remote start kit for Christmas it's a crime stopper rs4 G5 came with no install instructions and idk where the wires go can anyone help me and show me where all the wires connect to so I could get this thing to work I'd appreciate it a lot thanks
  2. justin13703
    justin13703 Senior Member
    28
    1,006
    296
    Oct 15, 2014
    MD
    Ram Year:
    2008
    Engine:
  3. Mikeyn23
    Mikeyn23 Member
    25
    52
    Sep 18, 2016
    Ram Year:
    2003
    Engine:
    Yea I found the wire diagram I just don't know which wires go where cuz the instructions to the crime stopper are confusing
  4. justin13703
    28
    1,006
    296
    Oct 15, 2014
    MD
    Ram Year:
    2008
    Engine:
    Honestly there is a lot to installing those types of remote starts. It's not just a connect a few wires type of deal. You need to know how to use relays, resistors, and diodes to do this type of install.
    Basically, if you find the directions confusing, you'd be better off letting a shop do it. I don't get into trying to walk people through a remote start install because they are very vehicle specific and require a lot of 12v electronics knowledge.
  5. crazzywolfie
    crazzywolfie Senior Member
    14,095
    2,147
    Apr 6, 2013
    under the truck
    Ram Year:
    81 93
    Engine:
    5.2
    i would have to agree with Justin. if you don't know what your doing you are best to have a professional do it. they can be pretty complicated to install especially if you are not familiar with wiring or security systems. i know a lot of newer vehicles come from the factory with security systems and immobilizers as my mom found out 1 cold winter day. if you mess things up it could cause way more issues and cost you more than paying a professional to do it right the first time.
  6. Mikeyn23
    Mikeyn23 Member
    25
    52
    Sep 18, 2016
    Ram Year:
    2003
    Engine:
    Yea I know what you mean I called around today and people want to much money to install it 400 500 bucks that's a little crazy to install it
  7. crazzywolfie
    14,095
    2,147
    Apr 6, 2013
    under the truck
    Ram Year:
    81 93
    Engine:
    5.2
    But the $400-500 also likely includes the bypass modules and everything needed to install a remote start in your specific vehicle. The more expensive the vehicle the more expensive the stuff is to install a remote start. There is more to getting a remote start than what is in the box at the store
  8. justin13703
    28
    1,006
    296
    Oct 15, 2014
    MD
    Ram Year:
    2008
    Engine:
    This is correct. If you have a chip in the key you will need an immobilizer bypass which is also a tricky install. 400 dollars to install the full system is normal. That's about what we charged to install them when I did installs. In a shop with all the right tools and equipment, and with trained professionals doing it, it will still take around 3-4 hours or more.
  9. Mikeyn23
    Mikeyn23 Member
    25
    52
    Sep 18, 2016
    Ram Year:
    2003
    Engine:
    Yea I don't have th chip so I don't need the bypass module my brother has the same truck but different remote start I was gunna try and follow off his wires but his remote start has different color wires then the one I got has so I couldn't do that only thing his truck has is two relays for th door locks to work I was trying to see if anyone installed one before or could help me and show me what wires go where
  10. argroft
    argroft Member
    40
    8
    Feb 28, 2016
    PA
    Ram Year:
    Engine:
    I just finished an install (with immobilizer bypass) on my 02, and although I can't help you solve you're wiring dilemma, I will mention that unless you are absolutely positive you know how to wire and program a remote start system to your truck, I wouldn't recommend doing it. You only have one ignition harness and if you mess it up or tap into the wrong wires, you could be looking at higher costs simply to fix things. Not to mention the possibly risk of causing an electrical fire.
    I'm not in any way doubting your ability to do this this though. I've just read enough horror stories from installs gone wrong and would hate to see try this and end up having issues.
Share This Page
