Need help with 5100s
Discussion in 'Lifted' started by Knightinraggedarmor, Jan 9, 2017.
  1. Knightinraggedarmor
    Knightinraggedarmor Junior Member
    23
    Jan 9, 2017
    Ram Year:
    2010
    Engine:
    Hi all new to the forum. I am about to inherit my dad's 2010 trx 4 and it needs shocks all the way around. I'm wanting to do 5100s all the way around to level it in the front but I haven't found anywhere that says if the rear 5100s need at least one inch of lift to fit correctly. So the question is will the rear 5100s fit without a rear lift?
  2. Ricks Ram
    Ricks Ram Senior Member
    1,770
    868
    May 1, 2015
    Ram Year:
    Engine:
    Yes they will fit. They are capable of handling up to1" of lift but are fine for stock height as well.
    DeereGuy likes this.
  3. Wrigley17
    Wrigley17 Senior Member
    100
    Jul 5, 2015
    Ram Year:
    Engine:
    What Rick said. I have front and rears on, stock height in back
  4. Knightinraggedarmor
    23
    Jan 9, 2017
    Ram Year:
    2010
    Engine:
    Awesome, what setting do I need to set the front at to get a perfect level or slight squat and what would be the largest tire size I could clear?
  5. Wrigley17
    100
    Jul 5, 2015
    Ram Year:
    Engine:
    Most will say 2.1. You're truck is already set st .7 from what I've read here.
  6. MaizeNBlue
    MaizeNBlue Senior Member
    463
    385
    Mar 25, 2016
    Ram Year:
    Engine:
    +1 on the 2.1 ;)
  7. Knightinraggedarmor
    23
    Jan 9, 2017
    Ram Year:
    2010
    Engine:
    What would be the biggest tire I could fit after the level? I want to full the wheel well up
  8. Synolimit
    Synolimit Senior Member
    108
    14
    Apr 5, 2013
    Ohio
    Ram Year:
    Engine:
    I'm 2.1 and rear 0.75. I just did 295/65/20 nitto G2 on the OEM wheels with no spacers. Zero issues! Mounted height is 3" over OEM.
  9. Knightinraggedarmor
    23
    Jan 9, 2017
    Ram Year:
    2010
    Engine:
    Well Im wanting to put some 305s on it, those should fit right?
  10. Alaskanpeeps
    Alaskanpeeps Member
    99
    21
    Mar 7, 2016
    Ram Year:
    Engine:
    305/55/20 is a stock height tire. (33")
Share This Page
