It’s actually 10 to 15 percent. 11.0 to 12.0 seems to work really well with even a flat nose TT with a WDH that has built in sway control. Assuming your not spending lots of time above 70 mph AND assuming your goal is to stay under GVWR for 4th gen (MY 09 to 18) 1500.
Sometimes with 8k TT & above it’s more safe & stable no tail wagging the dog to be above GVWR such as 15 percent instead of 10 percent. This way the weight on your truck axles stays more than the weight on your TT axles but can remain safely below max axle ratings.
Riccochet with a WDH the seen TW (actual scaled TW) is inclusive of the weight transfered back to the TT axles. So if your calculated TW is 1140 then it’s 1140. It’s calculated by subtracting the unloaded TV combined axles weight from the loaded TV combined axle weight. (With WDH static TW of trailer means nothing)
Examples with max GVWR 6950, max axles 3900, CVWR 15,950
Unloaded TV 2 adults supplies;
Steer. 3300
Drive. 2700
GVW. 6000
TT. 8000
CVW. 14000
Example with regular hitch 15 percent TW;
Steer 2900
Drive. 4300
CVW. 7200
(Drive weight exceeds added TW because TW lifted on front of TV transferring some steer weight to drive axle)
TT 6800
CVW 14000
Result: Light Steer, over Drive, over GVWR. Sways, reduced braking, skittish handling,
Example eyeball / measured WDH;
Steer. 3100
Drive. 4000
GVW 7100
TT. 6900
CVW 14000
Result: Better but still over Drive, over GVWR, doesn’t sway, improved braking, better handling, feels much better & relatively stable.
Example WDH & WD in TV & TT adjusted to scale results to 10 percent TW.
Steer. 3300
Drive. 3500
GVW. 6800
TT. 7200
CVW. 14000
Within Mfg specs, restored steer weight, full braking power, should’nt sway, stable handling, feels more like one unit with semi bowave or strong gust pushes on you.
Example WDH & WD set to 15 percent;
Steer. 3350
Drive. 3850
GVW. 7200
TT. 6800
CVW. 14000
Over GVWR but stops & handles the same except now TV axles have more weight on them than TT axles and tows like a boss no tale going to wag this dog.
I doubt they sticky this so if you think you may want to refer to this example in the future save it to your phone computer etc.
