daytona701
- Feb 17, 2018
- 11
- 1
- Location
- Carriere, Mississippi
- 2012, 2007
- Hemi 5.7, Cummings 6.7
Hi all, brand new to this forum. Wife's 2012 1500 developed misfire on #1 cylinder. Exhaust valve lifter failed and took out cam lobe. After looking at all options decided the best was to replace engine with reman from Accurate Engines. After installation took truck out and after 50 miles code P0521 came on. Changed oil pressure sensor and cleared code and has not come back on. Now on short run of 25 miles engine starts and sounds fine, oil pressure is good until engine warms up then when stopped at light or stop sign at idle oil gauge drops to 0 and low oil indicator on dash comes on. Don't want to destroy a brand new engine. The breakin oil is Valvoline 5w20 conventional. Accurate Engines or more specifically the salesman at Accurate Engines who wrote the sale said he preferred Dino oil. Change intervals are 500 miles first change then every 3000 miles or 3 months. After reading forum I now see how critical oil is to these new improved Hemi's. I had a 2003 5.7 2500 that went 225,000 and only needed new intake gaskets and got sold only because I had to start pulling a very heavy trailer. I also had a 2005 5.7 2500 work truck that went over 110,000 without any problems. This truck was at 88,000 and is babied when the lifter failed. Anyhow any and all advice comments will be greatly appreciated from the tremendous intellects on this forum. Thank you.
