New Key Fob
82Crew
North of St. Louis
318 Magnum, 6.7 Cummins
Is there a way to manually program new key fobs or do I have to have the factory scan tool to program? 2010 2500
RumRunner
Boston, MA
It can be done, but I think you need to have at least one good fob to do it. If you have an owners manual the steps for your truck should be in there. But if you don't have a good fob now, you will need to have the dealer do it.
82Crew
82Crew
North of St. Louis
I have one good one but no owners manual. Just bought this truck and it only came with one fob and an empty glove box
RumRunner
Boston, MA
Here is a link to a 2010 owners manual if you want it.
www.dodge.com/download/pdf/manuals/2010-Ram_Truck-OM-2nd.pdf
The manual doesn't say how to do it that I could see though. But I found this online, not sure if maybe it wasn't possible with your year, but you can try it. I know other years they can be programmed with one good fob.
Programming The Remote Keyless Entry (RKE) Module
1. Unlock the vehicle and disarm the Vehicle Theft Security System.
2. Insert ignition key into the ignition switch.
3. Turn the ignition switch to RUN position without starting the engine.
4. Using a functional key fob transmitter, press and hold the UNLOCK button for a minimum five seconds (maximum ten seconds).
5. While still holding the UNLOCK button, and before ten seconds passes, press the PANIC button and release both at the same time. A single chime will sound to verify that the RKE module is set to receive the new Vehicle Access Code(s).
6. Within 30 seconds of the chime, press and release the "LOCK" and "UNLOCK" buttons on the transmitter at the same time. Then press and release any one of the buttons. The BCM will sound an abbreviated chime to acknowledge that the programming of the transmitter has been completed and was successful.
7. Repeat step 6 for all transmitters that will be used with this vehicle, up to 4 total.
8. Programming mode will last for 30 seconds. To get out of programming mode sooner, turn the ignition OFF. A single chime will sound to verify that the RKE module will no longer accept additional Vehicle Access Code(s).
9. When Vehicle Access Code(s) programming is complete, turn the ignition switch to the OFF position and verify RKE system operation using each key fob.
82Crew
82Crew
North of St. Louis
The panic button is at the end of the fob which is the "key" so you physically can't reach it if the key is in the ignition. Thank you for looking!
spiG
CTD
From what I get from the instructions you place the one you are attempting to program in the ignition and the good one is where you do the pressing. Correct me if i'm wrong tho.
82Crew
82Crew
North of St. Louis
Maybe, hopefully I will get a new key fob soon and try it
Bulletfire18
Any news on this one i had a 2014 and dont really want to pay the dealer 90.00 shop time to program a new fob that cost me 120.00
stimpy433
IOWA
You use to be able to program your own key fob but you had to have 2 fobs that were already programmed, won't work with only1. Sometime around 2010-2011 they took that ability away and now you have to have a locksmith or the dealership program the fobs.
nateinva
Central Virginia
2011 1500 Laramie CC
5.7L
+1
I bought my 2011 used and it came with one key. Grabbed a blank/fob on eBay cheap, got local locksmith to meet me on lunch break. He cut a key and programmed for me for $60 in 10 minutes of his time. Key/fob blank was $27 to the door.
stimpy433
IOWA
I had a locksmith supply the FOB and program it and it cost like $100 bucks total.... the dealership was like 3 times that price!!!
norville
The cutoff is 2011, I unfortunately had to pony up $93 and 2 hours of my life to have extra gobs made. They did offer to do as many as 3 keys for that hour charge...
Wahrsuul
Central S.C.
So I could likely program a 2009 fob with no issues? Technically I have 2 that work, but one only works to start the truck, the lock/unlock and remote start buttons don't work.
stimpy433
IOWA
You should be able to since you have a 2009....
S0CAL
US Marine Veteran
The Lonestar State
2021 Limited Longhorn CTD HO DRW 4x4
Cummins 6.7L HO
This may also help. I had to replace my Wireless Ignition Module (WIN) and got 2 new factory keys in the process. Didn't go thru dealer either and saved over $300.
UnsatFC
Active duty NAVY
New Jersey
A shop local to me in Jersey programmed my second fob for $35. I have a 2015
